Sound in an Open Vertical Tube partially filled with Water
The calculations for sound in an open vertical tube partially filled with water are confirmed to be correct. The wavelength is determined to be 59 cm, which converts to 0.59 m. The frequency of the sound wave is calculated as approximately 581.36 Hz using the speed of sound at 343 m/s. The length of the air column is calculated to be 221.25 cm. It is emphasized that answers should be rounded to three significant figures due to the precision of the given values.
fjccommish
An open vertical tube has water in it. A tuning fork vibrates over its mouth. As the water level is lowered in the tube, the seventh resonance is heard when the water level is 191.75 cm below the top of the tube.
a What is the wavelength of the sound wave? The speed of sound in air is 343 m/s. Answer in cm.
b What is the frequency of the sound wave (the tuning fork) in Hz?
c The water continues to leak out of the bottom of the tube. When the tube next resonates with the tuning fork, what is the length of the air column? Answer in cm.
L = [(2n-1)w]/4
w = wavelength, n is resonance #
I think this is correct. Please verify.
a
L = (2n-1)w/4 so w = 4L/13
w = 4(191.75)/13 = 59 cm
b
59cm is .59m
f = v/w = 343/.59 = appox 581.36 Hz
c
L =(2*8-1)*59/4 = 15*59/4 = 221.25cm.
All looks good to me.
Thank you.
Can I add this...
The question gives the length of the air column to 5 significant figures (191.75 cm) and the speed of sound to 3 sig. figs. (343 m/s).
Your answers should be rounded to 3 sig. figs.
(Getting this wrong in an exam’ could cost you a mark.)
Thanks.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
