Sound intensity and distance problem
Henry measures the thunder's sound level at 65 dB, while Tom, located 800 m farther away, measures it at 63 dB. The calculated intensity ratio of the sound levels is 1.58, but the distance derived from this calculation is incorrect. The error lies in not taking the correct square root of the intensity ratio, which should be 1.584893192 instead of rounding. To find the actual distance from Henry to the lightning, the difference in sound levels must be properly interpreted, indicating that the distance is significantly greater than initially calculated. The correct answer is approximately 3090 m, highlighting the importance of precise calculations in sound intensity problems.
foobarbazzer
Henry and Tom see a flash of lightning and then hear the resulting clap of thunder. Henry measures the sound level of the thunder as 65 dB while Tom, who is 800 m further from the event, measures it as 63 dB.
I_H / I_T = 1.58
1 / d^2 = 1/1.58
d = sqrt(1 / 1.58)
= 0.796
0.796 * 800 = 636 m away, yet the answer is 3090 m.
Why?
I_H / I_T = 1.58
1 / d^2 = 1/1.58
d = sqrt(1 / 1.58)
= 0.796
Why?
In your calculation you say:
1 / d^2 = 1/1.58
d = sqrt(1 / 1.58)
Notice you have the reciprocal of the left [d] but not the reciprocal of the right.
You should have been taking the sqrt of 1,58.
Indeed you should not have rounded off, but been using 1.584893192 at least.
Once you have that answer consider the following.
If the answer had been 1.2, then 800m is the difference when going from 1 x distance from lightning to 1.2 x distance to lightning. 800m represents that extra 0.2, so the distance from Henry must have been 4000m
[ie 1.2 * 4000 = 4800 ; the extra 800m]
Now the answer is not 1.2, but that is how you have to treat the answer you do get.
