Spacetime Curvature Difference: Gravity vs Speed
Gerinski
Gravity causes spacetime to warp. Relative speed also causes an apparent warp from the point of view of the stationary observer.
But warp due to relative speed will cause rods to contract, rods will effectively measure shorter for the stationary observer. Accordingly we should also infer that something like a proton, which we assume to be roughly spherical, will appear as a vertically elongated shape, something like a banana, when subject to relative speed warp.
Warp due to a gravity well does not do that, a proton size and shape is the same in the center of a massive star or floating in the empty vacuum, always roughly spherical and the same size.
In which way is the spacetime curvature different when due to relative speed differences or when due to gravity wells?
There is no spacetime curvature due to relative speed differences.
There is no spacetime curvature caused by speed. Special relativistic effects such as length contraction and time dilation are not caused by warping or curving spacetime, they're just using different coordinates to describe something that's happening in flat uncurved spacetime.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
