Space-time curvature as gravity only for speeding particles?
In summary, the conversation discusses the concept of gravity and how it relates to the bending of space-time. It is mentioned that if gravity only bends space, then a stationary particle would not fall into its grasp. However, it is explained that the bending of space also has an effect on the size of objects, causing them to appear slightly smaller or larger depending on their proximity to a mass. The conversation also delves into the hypothetical scenario of removing space-time distortion and whether it could still capture a particle into an orbit. Ultimately, it is determined that the effect of space geometry alone is small in comparison to space-time geometry. The conversation also touches on the idea of feeling gravity and the impact of Heisenberg uncertainty on the concept of a stationary
Edi
177
If gravity rises from the fact that mass bends space-time and stuff falls in because it actually follows a straight line in a curved space as it moves by a gravitating object - doesn't that mean that a relatively stationary particle would not fall in the the claws of gravity as it would NOT be following a line at all?
At least stationary in the plane parallel to the surface because, as I think, moving UP perfectly perpendicular would not encounter curvature in such way to follow it down..
And I mean a stationary fundamental particle, because I know that "stuff" is made of atoms, that move around vibrating and atoms consist of nuclei and they of quarks and gluons and what not speeding inside like crazy (and the speeding quarks and gluons is what makes up most of the mass-energy of matter?).
Faster a particle moves the quicker it follows the line into the claws of gravity [falls] ?
Edi said:
If gravity rises from the fact that mass bends space-time and stuff falls in because it actually follows a straight line in a curved space as it moves by a gravitating object - doesn't that mean that a relatively stationary particle would not fall in the the claws of gravity as it would NOT be following a line at all? ... [falls] ?
That would be true if gravity bent space only, not space-time.
The bending with respect to time and space is approximately equal, so you can think of the effect of the time part as being similar to the effect on a particle moving through space at c. When the particle is moving near or at light speed, the effect of the bending of space doubles the effective acceleration to twice the Newtonian acceleration.
Ok, I did not take moving trough time in account, thank you.
But further thinking.. if it did bed just space, then this: "Faster a particle moves the quicker it follows the line into the claws of gravity [falls] " would be true.. ?
And if it did bend just space, then moving perfectly up would not feel the bend/ pull of gravity?
If stationary in space, it still advances through time.
https://www.youtube.com/watch?v=DdC0QN6f3G4
Yes
It would seem natural to think so, but actually the curvature of space has an additional effect, which is loosely speaking that space varies slightly in "size" because of the curvature, so a ruler which is a fixed size in local space appears slightly smaller closer to a mass and larger further away.
Even if the direction of the particle was straight up or down, this size effect means that the magnitude of its momentum in the downwards direction increases at a rate proportional to its speed, at the same rate as if it were moving sideways at the same speed (in which case the momentum change would be due to change in direction).
(For those who want to be picky about the details, the above description applies to a the path of a test mass described using isotropic coordinates in the weak field approximation for the GR Schwarzschild solution).
Half of the light deflection near the Sun is due to distorted space-TIME and half is due to distorted space itself. Theoretically, removing space-TIME distortion, could the space distortion capture a particle into an orbit about the Sun? (i.e. without "gravity")
This is getting very hypothetical, but I guess it's still just about meaningful enough to answer...
No, because for a light beam passing near the surface you've halved the deflection (which is already so small that Eddington had difficulty observing it), and for anything moving more slowly, the effect of the space part is merely that everything still follows the same shape of space, and hence the same path as the light beam.
(Even if the central mass is a black hole, the space component of curvature only closes to form a complete circle at the event horizon).
For objects moving fast (lightspeed) the effect of space geometry alone is in the same order as of spacetime geometry. For most objects it is tiny in comparison.
You don't "feel" gravity anyway in free fall. Due to symmetry gravity will not bend a radial path.
Code:
...doesn't that mean that a relatively stationary particle would not fall in the the claws of gravity as it would NOT be following a line at all?
'relatively stationary' is upset by Heisenberg uncertainty...there is always some motion.
Interesting. If we take something slower and more massive than light, space-time deflection is even greater than in the case of light, giving rise to orbit or further to collision. So you're saying that the space-deflection is not the same? The deflection due to this for a slow-moving mass would be less rather than more pronounced than in the case of light?
I do not think so.
Why do you think that to be true?
The angle of deflection due to curvature with respect to space is independent of speed. Particles just follow the shape of space.
Passionflower said:
I do not think so.
A fully detailed answer would be out of proportion to the level of this thread, but here's a rough summary.
Describe the space-time in a spherically symmetrical situation around a central mass using isotropic coordinates, where the scale factor relating coordinate space distances to local space distances is the same in all directions.
With all quantities expressed in those coordinates, including letting ##c## represent the coordinate speed of light rather than the standard value, the equation of motion is as follows:
$$\frac{d}{dt}\left ( \frac{v}{c^2} \right ) = \frac{1}{c^2} \, \left ( \mathbf{g}_t + \frac{v^2}{c^2} \mathbf{g}_{xyz} \right )$$
where ##\mathbf{g}_t## is the effective Newtonian gravitational field due to the gradient of the time scale factor and ##\mathbf{g}_{xyz}## is the equivalent field due to the gradient of the space scale factor. For GR (as described by the Schwarzschild solution) these two values are approximately the same, but you can also investigate the equation of motion for other cases, where the two scale factors are specified independently, which is what we have been discussing in this thread.
If you multiply both sides of the above equation by the total energy ##E## of a test particle (which is constant in free fall), the left side becomes the rate of change of coordinate momentum and the right side becomes the coordinate force.
Note that the right hand side is independent of the direction of travel, but depends on the speed. When the direction of travel is horizontal relative to the field, the rate of change of momentum is associated with a curved path. When the direction of travel is vertical, the rate of change of momentum also includes a term relating to the change in the coordinate value of ##c##. For a rising or falling photon which is already traveling at ##c## relative to the coordinates, the momentum is changing entirely because ##c## is changing.
How about this simple intuitive arguments, as for why a purely spatial distortion doesn't affect stationary objects:
To be affected by the geometry of a manifold you have to move within that manifold. If you are stationary with respect to the spatial dimensions, you are not affected by the spatial geometry.
A purely spatial distortion would mean that there is no gravitational time dilation, no gravitational red shift and therefore no potential difference that would cause a stationary object to start moving.
Are these two valid way to justify it?
Those points sound reasonable to me, but as "intuitive arguments" can lead one astray in relativity, especially if one's intuition isn't particularly experienced in the subject, I feel it is safer to use arguments based on calculations. In this case, the calculated results agree with your statements.
Jonathan, what is the time curvature of a Newton-Cartan spacetime?
Four dimensional spacetime does not evolve in time, spacetime describes everything that exists outside the realm of time. Nothing actually moves in spacetime, the idea of evolution, movement and time is simply a gauge choice.
I'm not sufficiently familiar with that concept to give a specific answer.
However, if it can be expressed as a metric theory with a static solution expressed in isotropic coordinates, then the coordinate acceleration of a particle initially at rest is determined entirely by the time component of the metric. This is what can loosely be described as the "curvature of the path with respect to time" within the coordinate system.
If the time scale factor is ##\Phi \approx (1 - Gm/rc^2)## then the specific expression for ##\mathbf{g}_t## in my previous post is as follows, where all quantities including the speed of light ##c## are as measured in the coordinate system, not local values.
$$\mathbf{g}_t = - c^2 \frac{1}{\Phi} \nabla \Phi$$
Okay right. I understand that if a body begins without velocity wrt the Sun, then curvature of space won't move it. If it were on a trajectory toward grazing the edge of the Sun, the space curvature would be getting more pronounced as it got closer to the Sun, and this would cause some curvature of its path. This should be without regard to its mass or its velocity. Okay, thanks.
Jonathan, do you see time on the spacetime manifold as some preferred direction?
Time is simply the evolution of a particular direction on the spacetime manifold, I do not see that if only 3 components of the 4 dimensional are curved things suddenly do not move with respect to each other.
For instance two separated points on a paraboloid. Now evolve the points by increasing h, the points will separate or come together depending on direction of h. No need to curve h.
That's where the word "static" comes in.
If we are talking about a situation involving a single central mass, with spherical symmetry, where the metric is not varying with time, then of course we are choosing a specific direction, which is related to a rest frame for the source location.
Of course, the idea of curvature with respect to space but not with respect to time in this situation is not consistent with the GR field equations, which require these to be approximately the same. However, it is still possible to identify the separate effects of the two components, as in isotropic coordinates the equation of motion for an arbitrary metric is easily split into two parts.
Not sure what you are trying to say here. But the manifold I talk about above is 3D space, not 4D spacetime, because the premise of the question was that only 3D space is distorted. Spatial geometry is defined by the spatial part of the metric, which defines the spatial distances. As long as you don't change your spatial position, why would spatial distances affect you in any way?
It's not about whether things can move with respect to each other, but if initially stationary free falling things must begin to move relative to each other, only because of spatial curvature. I see no reason for them to do so. They can simply stay stationary because as long they do, the distorted spatial distances have zero relevance to them.
Related to Space-time curvature as gravity only for speeding particles?
1. What is space-time curvature?
Space-time curvature is a concept in physics that describes how the presence of mass or energy can bend and distort the fabric of space and time. This distortion is what we perceive as gravity.
2. How does space-time curvature relate to gravity?
According to Einstein's theory of general relativity, mass and energy create a curvature in space-time, which is what we experience as gravity. The more massive an object, the greater the curvature and the stronger the gravitational pull.
3. Can space-time curvature only affect speeding particles?
No, space-time curvature can affect any object, regardless of its speed. However, the effects of space-time curvature are more noticeable for objects moving at high speeds, such as particles accelerated in a particle accelerator.
4. How does space-time curvature explain the motion of planets?
The curvature of space-time created by the sun's mass causes the planets to follow curved paths around it, which we perceive as their orbit. This is because the planets are moving through the curved space-time, and the curvature affects their motion.
5. Can we observe space-time curvature directly?
No, we cannot observe space-time curvature directly as it is a concept that describes the way space and time behave in the presence of mass and energy. However, we can observe its effects, such as the bending of light around massive objects or the motion of planets, which confirms its existence.
