What Are the Differences Between Bolts, Screws, and Hi-Lok Fasteners?
  • Thread starter Thread starter stan19
Bolts and screws differ primarily in their design and application; bolts typically require a nut for fastening, while screws are self-tapping and can be driven directly into materials. Hi-Lok fasteners are specifically designed for aircraft structures, offering high strength and reliability. They come in various nominal sizes with several oversizes available, allowing for adjustments in fit. The increments between nominal sizes and oversizes are standardized to ensure compatibility and performance. Understanding these distinctions is crucial for aerospace applications and licensing requirements.
stan19
First question: Whats the difference between bolt and screw?Any expert can give some reference info about it?
Second Q: Hi-Lok is commonly use on aircraft structure. Anyone can give more info about the spec of it? such as oversizes? how many oversizes are there for a norminal size? what's the increment of norminal size as well oversizes.
Thank you, i need all these answer for license interview
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
