Special Relativty and Inertial Reference Frames
SudanBlack
Hi - I've just started having lectures on special relativity at uni. We were talking about inertial reference frames and how these can be characterised by the facts that:
1) They move relative to one another with constant velocity, and
2) Newton's laws operate in inertial reference frames.
Now, we pressume that Newton's laws are true on earth. However, this is not traveling at a constant velocity, since there is a centripetal acceleration towards the sun. So how can we still class the Earth as an inertial reference frame?
Thanks in adnvance. :smile:
The "non-inertial" component is VERY weak under most circumstance. Try it yourself.
Sit on a rotating platform and put a ball on the platform. Now, try the same thing with our earth. Put a ball on your desk and see if you observe the same effect. No? Then for all practical purposes, you do not detect this centripetal component due to Earth's orbit around the sun.
Zz.
Your point (2) is not true in SR.
The rotation of the Earth is a more important non-inertial effect than its acceleration. The rotation causes hurricanes, etc. For table top experiments, the Earth can be considered a reasonable inertial frame if the equivalence principle of GR is not applied to g.
I think that both statements are incorrect, or at least they are incomplete.
We can certainly have two inertial reference frames that move relative to each other where the velocity is not constant. This is that case in a gravitational field. And at relativistic speeds it is not Newton's laws but GR that operates in inertial reference frames.
Seems to me a bit of a straw man argument, since who claims it is? :confused:
A spinning sphere is obviously not an inertial reference frame.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
