Specific Gravity and antifreeze
In summary, specific gravity is a measure of the density of a substance compared to water and is important in antifreeze because it determines the concentration of ethylene glycol. It is typically measured using a hydrometer and has a direct impact on the boiling point of antifreeze. The ideal specific gravity depends on the climate and can change over time, so it is important to regularly check and maintain it for proper protection.
mcs117
If 5.0L of antifreeze solution (0.8 specific gravity) is mixed with 4L of water to make a 9.0 L mixture. what is the specific gravity of the mixture?
SG = density of substance / density of water
I am confused as in how to gain the density from the substance gravity. Is it given that the density is 1 g/cm^3 for water?
Use CGS system -- there the specific gravity is numerically equal to the density in gm/cc.
1 L = 1000 cc = 1000 mL.
I would approach this problem by first understanding the concept of specific gravity and how it relates to density. Specific gravity is a unitless measure of the density of a substance compared to the density of water. In other words, it is the ratio of the density of the substance to the density of water.
To solve this problem, we can use the formula SG = density of substance / density of water. However, we need to know the density of the antifreeze solution and the water in order to calculate the specific gravity of the mixture.
The specific gravity of the antifreeze solution is given as 0.8. This means that the density of the antifreeze solution is 0.8 times the density of water. We can also assume that the density of water is 1 g/cm^3, as this is a commonly used value for the density of water.
Now, we can use the formula SG = density of substance / density of water to calculate the density of the antifreeze solution. Rearranging the formula, we get density of substance = SG * density of water.
Substituting the values, density of substance = 0.8 * 1 g/cm^3 = 0.8 g/cm^3.
Next, we need to calculate the total volume of the mixture. This can be done by adding the volumes of antifreeze solution (5.0 L) and water (4.0 L), which gives us a total of 9.0 L.
Finally, we can calculate the specific gravity of the mixture using the formula SG = density of mixture / density of water. The density of the mixture can be calculated by dividing the total mass of the mixture by the total volume of the mixture.
The total mass of the mixture can be calculated by multiplying the density of the antifreeze solution by its volume and the density of water by its volume. This gives us a total mass of (0.8 g/cm^3 * 5.0 L) + (1 g/cm^3 * 4.0 L) = 8.0 g/cm^3.
Therefore, the specific gravity of the mixture is SG = (8.0 g/cm^3) / (9.0 L) = 0.89. This means that the density of the mixture is 0.89 times the density of water, which is slightly higher than the density of pure water.
In conclusion
1. What is specific gravity and why is it important in antifreeze?
Specific gravity is a measure of the density of a substance compared to the density of water. In the context of antifreeze, it is important because it determines the concentration of ethylene glycol, the main ingredient in antifreeze. A higher specific gravity means a higher concentration of ethylene glycol, which provides better protection against freezing temperatures.
2. How is specific gravity measured in antifreeze?
Specific gravity is typically measured using a hydrometer, which is a device that measures the density of a liquid. The hydrometer is immersed in the antifreeze and the specific gravity is read from a scale on the device. Alternatively, some antifreeze products may also include the specific gravity measurement on the packaging.
3. How does the specific gravity of antifreeze affect its boiling point?
The specific gravity of antifreeze has a direct impact on its boiling point. As the concentration of ethylene glycol increases, the boiling point of antifreeze also increases. This means that antifreeze with a higher specific gravity will provide better protection against overheating in the summer months.
4. What is the ideal specific gravity for antifreeze?
The ideal specific gravity for antifreeze depends on the climate in which it will be used. In colder climates, a higher specific gravity (around 1.13) is recommended for better protection against freezing temperatures. In warmer climates, a lower specific gravity (around 1.07) is recommended to prevent overheating.
5. Can the specific gravity of antifreeze change over time?
Yes, the specific gravity of antifreeze can change over time due to dilution with water or evaporation of the ethylene glycol. It is important to regularly check the specific gravity of antifreeze and top up or replace it as needed to maintain proper protection for your vehicle.
