Higher Specific Heat Capacity: Explained
Higher specific heat capacity in an object means it absorbs more heat energy without a significant rise in temperature compared to an object with lower specific heat capacity. This phenomenon can be explained by the First Law of Thermodynamics, which states that the increase in internal energy is due to heat transfer and work done on the system. The temperature reflects only translational kinetic energy, while some absorbed energy may convert to potential energy or other forms such as vibrational or rotational energy. Thus, objects with higher specific heat capacity may store energy differently, leading to less kinetic energy increase. Understanding these concepts clarifies how thermal energy is distributed among different forms in materials.
Yh Hoo
Now consider two objects,A and B. A has a higher specific heat capacity that B. When both object is subjected to same amount of thermal or heat energy, rise in temperature in A is lower as our common reason(A has a higher specific heat capacity)
But what stated by First law of thermodynamics that Increase in internal energy is caused by heat energy transfer to in and work done on it. since temperature is a measure of average kinetic energy of particles in a system, it means perticles in A has a greater amount of kinetic energy than B. Meanwhile , energy should be conserved, so it means portion
heat energy flow to A and is stored as kinetic energy of particles is lower than B.
NOW, WHERE DOES THE REST PORTION OF THE THERMAL ENERGY FLOW TO A converted to? the electrical potential energy(another component of internal energy) of the particles in A ?
if so that means object with high specific heat capacity has a lower tendency to store the thermal energy received in the form kinetic energy of particles?
can somebody explain this to me? or correct me if i am wrong. Thanks a lot.
Science news on Phys.org
Temperature is the measure of only one kind of kinetic energy: translational kinetic energy (energy due to the motion of the centre of mass of the molecules). Rotational and vibrational kinetic energies do not directly affect temperature.
it means particles in A has a greater amount of kinetic energy than B. Meanwhile , energy should be conserved, so it means portion
Your question is a good one. There are two aspects to this. Higher heat capacity could be due to stronger forces between molecules (so some energy is stored as potential energy). It could also be due to additional degrees of freedom of the molecules (some energy stored as vibrational or rotational energy of molecules).
AM
Likes Gvozden
wow thanks a lot! it is sufficient for me already as a pre u student.
Thread 'Can somebody explain this: Planck's Law in action'
Plotted is the Irradiance over Wavelength. Please check for logarithmic scaling. As you can see, there are 4 curves. Blue AM 0 as measured yellow Planck for 5777 K green Planck for, 5777 K after free space expansion red Planck for 1.000.000 K To me the idea of a gamma-Ray-source on earth, below the magnetic field, which protects life on earth from solar radiation, in an intensity, which is way way way outer hand, makes no sense to me. If they really get these high temperatures realized in...
  • · Replies 28 ·
  • · Replies 26 ·
