Specific heat, latent heat, and temp
The discussion focuses on a system cooling from 21°C to 0°C in a freezer, taking 10 minutes to reach freezing before continuing to cool. The cooling power is constant at 36.6 J/s, and the latent heat of fusion for ice is 333.7 J/g. After freezing, the remaining time to calculate the temperature T_B after one hour is 722 seconds. The calculations involve energy transfer for cooling and phase change, but the mass of the system must be specified for precise calculations. The participants emphasize the need to clarify the time intervals and energy equations to determine the final temperature accurately.
jaded18
The system, originally at T_A = 21.0 Celsius, is placed in a freezer, where energy is removed from it in the form of heat at a constant rate. The figure shows how the temperature of the system takes t_1 = 10 min = 600 s to drop to 0 Celsius, after which the water freezes. Once the freezing is complete, the temperature of the resulting ice continues to drop, reaching temperature T_B after an hour.
http://session.masteringphysics.com/problemAsset/1013967/12/1013967B.jpg
If the cooling power remains constant, what will be the temperature of the system T_B after it has been in the freezer for exactly 1 hour? This temperature is off scale on the figure.
also: latent heat of fusion (ice to water phase change at 0 Celsius) = 333.7J/g
____________________
I know that after the water cools to 0 Celsius and freezes, the time that remains before the one hour mark is 722 sec and that the constant cooling power is 36.6J/s which I got by determining how much energy that has to be transferred out of the system as heat Q to lower its temperature to 0 =(2.20*10^4) and dividing it by 600s.
So... that means that in addition to 2.20*10^4 J that was required to bring the T from 21 to 0, we have to consider the energy for phase change (Q=mL=250(333.7)) and also the energy that I calculated to be 26425.2 J in the very beginning with the cooling power and time.
I feel like I'm going around in circles. Help?
I have just one confusion. You have to find the temp of the whole thing after two hours from the start at 21 C?
no, I thought I said ONE hour...
(You mentioned “system T_B after it has been in the freezer for exactly 1 hour?” Hence the confusion.)
You cannot get the absolute value of heat transfer rate because you haven’t specified the mass.
Take the mass to be m, sp heat of water to be s, sp heat of ice to be s2, time for water to cool to zero t1; time for water to freeze is t2 –t1, and time for ice to cool to T_B be t3. Initial temp of water is T_A=21 C, final temp of ice is (-T_B). L is the latent heat of fusion.
If the rate of heat taken away is constant, then,
ms(T_A)/t1 = mL/(t2-t1) = ms2*(T_B)/(t3-t2)
m cancels out. s2 is reqd. t2 can be found from the 1st two eqns.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
