Deriving Speed at an Inclined Plane
In summary: The correct equation to use would be v^2=u^2+2as. if you used the equation in your OP, then you should have solved quadratically for t and substituted t into (v-u)=at.this should be enough...
zcabral
30
A block slides down a frictionless plane having an inclination of = 12.2° (Fig P5.22). The block starts from rest at the top and the length of the incline is 2.85 m.
F=ma
xf=xi+vit+1/2at^2
i tried to solve this by using the kinematic equation above. i know the acceleration is 2.07 m/s^2 so i plugged it into find t in order to find speed but it didnt work. I am totally stuck. i know if i find t i could find the answer by absolute value v=dx/dt
If you're searching for the velocity of the block at the very bottom of the ramp, you actually utilize Energy conservation instead of kinematics.
PE = mgh
KE = 1/2*mv^2
The block is at rest on top of the incline plane, which means no KE and only PE. That means it starts out with a total E of m*9.8*(2.85*sin 12.2)
At the bottom of the ramp, all that PE has been converted into KE.
KE = 1/2(m)(v^2)
So since E is conserved because there is no friction on the ramp nor air drag, set PE = KE and solve for V. Note that your masses will cancel out.
the mass is not given
no problem, if the mass is the same in the begin and in the end, they cut in the equation... state the equation on a paper and you will see
although its much easier to do by consrevation of energy, but you should also reflect on why kinematics did not work for you. Are you still weak in kineatics? You may have escaped from using kinematics from this question but not all questions can be solved by conservation of energy,The correct equation to use would be v^2=u^2+2as. if you used the equation in your OP, then you should have solved quadratically for t and substituted t into (v-u)=at.
velocity at the bottom of an inclined plane is independent of angle of inclination...
infact it is given by...
v=[(2)gh]^1/2
v=[(2)gh]^1/2
I think it would be way better to derive this result rather than to mug this equation and plug the numbers into it
well you are right but is it a too difficult equation my frnd?
Related to Deriving Speed at an Inclined Plane
1. What is the formula for calculating speed at an inclined plane?
The formula is Speed = Distance/Time, where the distance is measured along the inclined plane and time is the total time taken to travel that distance.
2. How does the angle of the inclined plane affect the speed?
The steeper the angle of the inclined plane, the faster the object will accelerate, resulting in a higher speed. This is because the gravitational force acting on the object is greater on steeper inclines.
3. Can an object have different speeds at different points on an inclined plane?
Yes, the speed of an object can vary at different points on the inclined plane. This is because the object's speed is affected by the slope of the plane and the force of gravity acting on it.
4. How does the mass of an object affect its speed on an inclined plane?
The mass of an object does not directly affect its speed on an inclined plane. However, heavier objects may require more force to overcome the frictional force on the plane, resulting in a slower speed.
5. What is the difference between speed and velocity on an inclined plane?
Speed is a measure of how fast an object is moving, while velocity is a measure of how fast an object is moving in a specific direction. On an inclined plane, the speed of an object may change, but its velocity will remain constant if it is moving in a straight line.
