Speed of a cap when released from a pressure vessel
The speed of a cap released from a pressure vessel is influenced by several factors, including the mass of the cap, the pressure inside the vessel, and the geometry surrounding the cap. When the cap is removed, the pressure must be released, and the initial force acting on the cap is calculated using the formula F = p * π * r^2, where p is the pressure and r is the radius of the cap. The final velocity can be estimated with the equation v = Δt * (p * π * r^2) / (2M), assuming a linear decrease in pressure over time Δt. For example, with a pressure of 10 psi, a 10 kg cap, and a 50 cm diameter, the estimated speed could reach approximately 134.43 m/s. Accurate calculations depend on specific conditions and additional factors such as cap spinning and pressure dissipation.
Benjamin2019
Hi,
Pressure vessels have caps on top of them. These caps are secured with tri clamps and if you need to remove them you have to make sure that the tank's pressure is released. If the tank is under pressure (say 10psi) and an operator removes the cap (A is known), what is the speed of the cap?
Hello Benjamin, ##\quad## :welcome: ##\quad## !
For starters you can assume an acceleration of ## A\Delta p /m## with ##m## the mass of the cap.
To estimate final speed you have to estimate how long the ##\Delta p## lasts effectively. That isn't so clear cut and requires more detailed knowledge.
Manhole covers https://www.telegraph.co.uk/news/worldnews/northamerica/usa/11534365/Explosion-shoots-manhole-cover-100-feet-into-air.html are a well known source of fatal accidents
Likes Benjamin2019 and russ_watters
Thank you for the quick reply. If Δt is known, what is the formula to find the speed?
Pressure vessels "cap" are not fitted to the outside, they are usually oval shaped and fitted internally with the clamps holding them up from inside against the vessel opening. So even if you undo the clamps with pressure inside the pressure will hold the "cap' in place till all pressure is released(by valve open etc).
Like others said, it really depends on the specific system. There are many factors that influence the final velocity of the cap, such as the mass of the cap, the surface area of the cap, how large the pressure vessel is and the overall geometry around the cap. On top of that, if the pressure is allowed to escape past the cap while it's accelerating (which I assume it would be), or the cap reaches the speed of sound in the pressurized gas, the process becomes more difficult to model.
I'm not entirely sure how sharply the pressure decreases as soon as some of the gas can escape, but for a rough estimate, we can assume that the pressure decreases linearly to 0 over Δt, which you've said is known.
The initial force on the cap is based on it's cross-sectional area and the pressure in the vessel. The formula for that is ##F = p * π * r^2##, where p is the pressure and r is the radius of the cap. The force also decreases linearly to 0 over Δt. Because the decrease in force is linear, this is equivalent to half of the initial force being applied the entirety of that time.
To get the velocity, all we have to do then is get the acceleration and multiply it by the amount of time the force is applied for: ##V = Δt * F/M##
Putting all that together, we get:
$$v = Δt * \frac {p * π * r^2} {2M},$$
where v is the final velocity, p is the pressure, r is the radius of the cap, and M is the mass of the cap.
Assuming a pressure of 10 psi (which is roughly 68.95 kPa) and a cap that weighs 10 kg and has a diameter of 50 cm, and assuming the pressure dissipates entirely in 50 ms, we get:
$$v = 0.05 * \frac {68500 * π * 0.5^2} {2 * 10} = 0.05 * \frac { 53772.5 } {2 * 10} = 134.43125 m/s ≅ 441 ft/s$$
Note that this doesn't consider other factors such as that the cap will likely begin spinning immediately, which both releases the pressure faster and decreases the affected surface area. I also don't know how realistic the values I picked are. :^)
To give you a better answer, I'd need to know more about the specific case you're working with.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
