Speed of a Wave (Literal Wave)
  • Thread starter Hypnos_16
  • Tags
    Speed Wave
In summary, a jetskier moving at 8.30 m/s in the direction of the waves on a lake experiences a bumping frequency of 1.17 Hz with crests 5.30 m apart. The wave speed can be calculated using the equation v = ƒ(wavelength) and the relative velocity of the skier with respect to the waves. This results in a wave speed of 6.201 m/s, but this is not accurate as the skier and waves are moving in the same direction. By considering the relative velocity of the skier and using the equation distance = speed times time, the correct wave speed of 8.3 m/s can be calculated.
Hypnos_16
153
A jetskier is moving at 8.30 m/s in the direction in which the waves on a lake are moving. Each time he passes over a crest, he feels a bump. The bumping frequency is 1.17 Hz, and the crests are separated by 5.30 m. What is the wave speed?
Jetski's Speed = 8.30m/s with the waves
ƒ of waves= 1.17
wavelength = 5.30m
v = (wavelength)ƒ
when i tried the equation above i got an answer of 6.201m/s which turned out to now be right. What am i missing here?
v = ƒ(wavelength)
v = (1.17)(5.30)
v = (6.201m/s)
The waves are moving forward at the same time that the boat is, so the frequency of the bumps that the skier feels is not the frequency of the wave.
I suggest that you draw a diagram showing a wave at some starting time (zero is a good number), with the jetski at a wavecrest. The jetski will hit the following wavecrest at a time consistent with the given bump frequency. So, draw another wave below the first but shifted over to reflect that the wave has moved during that time interval. See if you can't work out the wave speed from there.
It is easy to solve this problem by using the relative velocity of the skier with respect to the waves. If the velocity of the waves is V, the relative velocity of the skier is 8.3-V (m/s), as they move in the same direction. You can imagine a standing wave pattern with crests 5.30 m apart. The skier travels this distance with its relative velocity in 1/f time (f is the frequency of the bumps). Just use the relation "distance = speed times time".
ehild
ehild
Why would it be 8.3 - V if they go in the same direction? wouldn't they add up? Also how does the skier have two relative velocities? (8.3 - v) and (1 / ƒ)
I'm still not getting it.
Imagine you sit on a train and another train travels beside you with the same velocity Does it seem moving at all?
The skier moves with velocity v(rel)=8.3-v during a time interval T=1/f. The distance traveled is 5.3 m.
ehild
Okay, yeah that makes sense now, i don't know how that didn't click before, thanks for your help man.
1. What is the speed of a wave?
The speed of a wave is the distance that a wave travels per unit of time. It is usually measured in meters per second (m/s) or kilometers per hour (km/h).
2. What factors affect the speed of a wave?
The speed of a wave is affected by the medium it is traveling through, the frequency of the wave, and the wavelength of the wave. The medium's properties, such as density and elasticity, determine how fast the wave can travel through it.
3. Can the speed of a wave change?
Yes, the speed of a wave can change as it moves from one medium to another. It can also change if the properties of the medium it is traveling through change. For example, the speed of sound waves changes as it travels from air to water.
4. How is the speed of a wave calculated?
The speed of a wave can be calculated by multiplying the wavelength of the wave by its frequency. The formula is v = λ * f, where v is the speed, λ is the wavelength, and f is the frequency.
5. Is the speed of a wave the same as the speed of the particles in the wave?
No, the speed of a wave and the speed of the particles in the wave are not the same. The particles in a wave oscillate or vibrate, but they do not actually travel with the wave. The wave itself is what travels through the medium, not the particles.
53K
