How Does a Water Drop's Speed Change as It Falls and Gains Mass?
martyg314
This is for a mechanics class. I'm sort of re-learning how to apply calculus and differential equations in this class, so I get stuck trying to figure out how to apply the math I learned 2 or more semesters ago. Any help would be greatly appreciated.
Thanks,
m.g.
"A spherical water drop falls through the atmosphere and its mass increases at a
rate proportional to its area. Find the speed of the drop as a function of time, assuming
that the drop started with zero initial speed."
- disregard drag in this problem
- starting mass is a finite mass
- for the area, cross sectional area or surface area can be used, but cross-sectional area will probably be easier
I modeled this as a momentum problem, similar to a rocket losing mass as it accelerates, but instead as a drop gaining mass as it falls
the increase in mass is proportional to the area (I used the cross section):
\frac{dm}{dt} = k4\pir^{2}
The forces are gravity and the changing momentum:
F=mg-\frac{dp}{dt}
which simplifies to:
\frac{dv}{dt} = g - (\frac{v}{m})\frac{dm}{dt}
Substituting in, I get the differential equation which is where I'm stuck:
\frac{dv}{dt} = g - (\frac{v}{m})k4\pir^{2}
I think I need to remove the m from the equation to solve for v but since r changes as a function of time as well, that doesn't seem to help.
m = (4/3)πr3ρ ?
could you not deduce from the mass differential equation that dr/dt is a constant
Thanks for the tips. I think I finally got it.
Knowing that \frac{dR}{dt} is constant, R = kt + R0
I also used the mass/volume/density equation suggested above.
I switched variables to get the equation:
\frac{dv}{dR} = \frac{g}{k} - \frac{3v}{R}
(\rho omitted since we are dealing with water)
And I solved from there.
Thanks for the help. I can see how relatively simple it is now.
-mg
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
