Speed of light in certain medium
Light travels at different speeds in various materials, with its speed in a medium determined by the refractive index. Given a speed c1 in a medium with a refractive index of 1.2, the speed in a medium with a refractive index of 1.6 can be calculated using the formula n1 v1 = n2 v2. The calculation shows that the speed v2 equals 0.75 c1, but this answer does not match any of the provided options. The discussion raises a question about whether the light is entering from air into the medium in both cases. Clarification on the question's context is needed for accurate resolution.
songoku
Light travels at different speed through different materials. If it travels at speed c1 in a medium of refractive index 1.2, what is its speed in a medium of refractive index 1.6
a. 1.3 c1
b. 0.67 c1
c. 2 c1
d. 1.7 c1
e. 0.55 c1
n=\frac{c}{v}
n1 v1 = n2 v2
v2 = v1 * n1/n2 = 1.2/1.6 * c1 = 0.75 c1 ??
Your answer is correct, but there is no choice!
Check the question. Whether the light is entering from air to medium in both the case?
Hi Mr. rl.bhat
That's all the question. Thanks a lot for your help :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
