Speed of water flowing through pipe
  • Thread starter Thread starter thatshowifeel
    Pipe Speed Water
The speed of water flowing through a 4-inch diameter pipe is 3.0 ft/s, and the volume flow rate can be calculated using the formula Q = A x V, where A is the cross-sectional area and V is the velocity. To find the flow rate, the area of the pipe must be calculated using the formula A = πr². The discussion emphasizes that the flow rate remains constant throughout the piping system, meaning that if the diameter changes, the speed of water will also change inversely. Thus, to find the speed in a smaller 3-inch diameter section, the same flow rate can be used to determine the new velocity. Understanding these principles is crucial for solving the problem correctly.
thatshowifeel
The speed of water flowing through the "influent" 4-inch diameter section of the piping system below is 3.0 ft/s. What is the volume flow rate of water in the piping system? Express the volume flow rate in ft^3/s
I really don't know what to do. I know pi*r^2 comes into play here, but I need help. Just tell me how to start and guide me through it please.
Flow rate = area of the pipe multiplied by the velocity.
You have everything but the flow rate. The area of the pipe is pi*r^2 as you said. Since you're not given a second density we can assume the flow is incompressible, and due to the conservation of mass, the flow rate in the 3 in dimater pipe will be the same. Q1 = Q2. I can't give you anymore without solving it for you.
Given that the fluid is water, it's safe to assume that the fluid is incompressible.
Vadar2012 said:
... the flow rate in the 3 in dimater pipe will be the same. Q1 = Q2.
Can the speed of the water be different even though the flow rate is the same? Part two says to find the speed of the water in the 3-inch diameter section in ft/s
Yes.
Yes, this is connected to the equation given by vadar2012: flow rate = area x velocity.
The flow rates are the same everywhere in the pipe (it must be, the water doesn't disappear). Therefore, if the area of the pipe increases, the velocity decreases.
So:
step 1: calculate flow rate = area x velocity or Q1=A1 x V1
step 2: use Q1 = Q2 to calculate V2
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
