How Do You Calculate Trip Duration and Distance with Stops and Average Speed?
  • Thread starter aquapod17
  • Tags
    Speed Time
In summary, the problem involves finding the time and distance traveled by a person who takes a trip with a constant speed of 90.5 km/h, but has a 22.0 minute rest stop. Using the equation v = d/t, we can determine that the distance traveled is the same before and after the rest stop, giving us the equation 90t = 73.4(t + 22/60). From here, we can solve for t and then calculate the total time and distance traveled.
aquapod17
A person takes a trip, driving with a constant speed of 90.5 km/h except for a 22.0 min rest stop. If the person's average speed is 73.4 km/h, how much time is spent on the trip and how far does the person travel?
v = d/t
I have no idea how to solve this, other than that I have to plug the values into the average speed formula.
v = d/t
From your equation you know that d = V*t
If you hadn't stopped you know that 90.5*t is the distance
But you did stop 22 minutes (which is 22/60 hours) so to do the same distance it was 73.4*(t+22/60)
Since the distance is the same then 90*t =73.4*(t+22/60)
I'm sure you get the idea from here.
I would approach this problem by first understanding the given information and identifying the key variables involved. In this case, we are given the speed (v) of 90.5 km/h, the rest stop time (22.0 min), and the average speed (73.4 km/h). The distance (d) traveled is also unknown.
To solve for the distance, we can use the formula v = d/t, where v is the average speed and t is the total time. We can rearrange this equation to solve for d, giving us d = v*t. We know that the average speed is 73.4 km/h, so we can substitute that into the equation. However, we need to convert the rest stop time of 22.0 min into hours, which is 0.367 hours. Plugging in the values, we get:
d = (73.4 km/h)*(t + 0.367 h)
Now, we also know that the total time is equal to the time spent driving (t) plus the rest stop time (0.367 h), so we can substitute that in as well:
d = (73.4 km/h)*(t + 0.367 h) = (90.5 km/h)*(t)
We can now solve for t by setting the two equations equal to each other:
Solving for t, we get t = 1.5 hours. This is the time spent driving. To find the total time of the trip, we need to add the rest stop time of 0.367 hours, giving us a total time of 1.867 hours.
To find the distance traveled, we can plug in the value of t into either of the equations we set equal to each other. Using the equation d = (90.5 km/h)*(t), we get d = (90.5 km/h)*(1.5 h) = 135.75 km. Therefore, the person traveled 135.75 km on their trip.
In conclusion, the person spent 1.867 hours on their trip and traveled a distance of 135.75 km. By understanding the relationship between speed, time, and distance and using the appropriate equations, we were able to solve for the unknown variables and answer the given questions.
What is the formula for calculating speed?
The formula for calculating speed is speed = distance/time. This means that to find the speed, you need to divide the distance traveled by the time it took to travel that distance.
What is the difference between speed and velocity?
Speed and velocity are often used interchangeably, but they have different meanings in physics. Speed is a measure of how fast an object is moving, while velocity is a measure of both the speed and the direction of motion.
How do you convert units of speed, time, and distance?
To convert units of speed, time, and distance, you can use conversion factors. For example, to convert from miles per hour to meters per second, you can use the conversion factor 1 mph = 0.44704 m/s. To convert from hours to seconds, you can use the conversion factor 1 hour = 3600 seconds.
What is the relationship between speed and distance?
The relationship between speed and distance is direct. This means that as speed increases, distance also increases, and as speed decreases, distance decreases. This relationship is described by the formula speed = distance/time.
How does time affect speed?
Time and speed have an inverse relationship. This means that as time increases, speed decreases, and as time decreases, speed increases. For example, if you are driving a car and you increase your speed, you will reach your destination faster. On the other hand, if you decrease your speed, it will take you longer to reach your destination.
20K
