Speed when Spring is Stretched
  • Thread starter Thread starter Manni
    Speed Spring
The discussion focuses on calculating the speed of a 1.50 kg block attached to a spring with a spring constant of 19.6 N/m when a constant horizontal force of 20 N is applied, causing the spring to stretch 0.300 m. Participants emphasize the importance of using the work-energy theorem and correctly identifying the total energy in the system. The correct approach involves calculating the work done by the applied force and the energy stored in the spring to find the block's speed. The final speed calculation must consider the displacement from the equilibrium position, not just the stretch of the spring.
  • Understanding of the work-energy theorem
  • Knowledge of spring potential energy (U = (1/2)kx²)
  • Familiarity with kinetic energy (K.E. = (1/2)mv²)
  • Basic principles of mechanics involving forces and motion
  • Study the work-energy theorem in detail
  • Learn how to calculate work done by a constant force
  • Explore the relationship between kinetic energy and potential energy in mechanical systems
  • Investigate the dynamics of oscillating systems and simple harmonic motion
Physics students, educators, and anyone interested in understanding the dynamics of forces and energy in mechanical systems.
Manni
A 1.50 kg block is at rest on a table and is attached to a horizontal spring with a spring constant of 19.6 N/m. The spring is initially not stretched. A constant force of 20 N horizontal force is applied to the object causing the spring to stretch. Determine the speed of the block when it has stretched 0.300 m. Assume the table is frictionless.
The way I did it:
E = (mv^2)/2 + (kx^2)/2
1/2kA^2 = (mv^2)/2 + (kx^2)/2
Do I simply rearrange for speed?
What about the 20 N force? Where does that come in?
(But considering energy is the right idea.)
I use it to find the amplitude
F = -kx
20 = -kA
-A = 20/k
Negative sign can be omitted since amplitude is treated in a A/-A fashion.
F = -kx
20 = -kA
-A = 20/k
No, that's not quite right. The force is continuously applied. Instead, consider the work done by that force.
Yes, you can rearrange for v. :D
Great, but when I did that I still got the wrong answer.
The answers I have to choose from are:
4.47 m/s, 70.6 m/s, 44.7 m/s, 2.61 m/s, and 8.96 m/s
Another hint. You'll use this:
But what's E? What's putting energy into this system?
what's your wrong answer? and what's the right one?
I got 3.52 m/s, and it's not even offered as one of the choices.
No you can't.
Then, I'm getting curious. E = (mv^2)/2 + (kx^2)/2 can't he simply rearrange for v? O_O why?
Before solving for v, you must first find the correct expression for the energy, E.
Think about this: the spring and the mass can be thought as a system, then you apply a force F on it... so what happens to the energy?
Work energy theorem seems like the simplest way to solve it.
Oh, I got it!
You need to sub in (A-0.300) meters for x, and not 0.300 m!
Manni said:
Oh, I got it!
:confused:
At the point in question, the displacement from equilibrium x is given as 0.300 m. (Forget about the amplitude; this is not SHM.)
Elastic P.E + K.E = Total Energy = Work done when the mass travels 0.3m under a force whose magnitude is 20N
  • · Replies 20 ·
