Spherical balloon with conductive coating
The discussion centers on calculating the voltage and outward pressure for a spherical balloon with a conductive coating, inflated to a diameter of 0.1 meters and connected to a high voltage source. The maximum electric field at the surface is specified as 2 x 10^6 volts/meter. Participants confirm that Gauss's Law can be used to find the total charge on the sphere, and the voltage can be calculated using the relation V = Er, leading to a voltage of 100,000 volts when the correct radius is applied. There is uncertainty regarding the calculation of outward pressure, with suggestions to use force equations, but doubts arise about the applicability of these equations due to the electric field being zero inside the conductor. The conversation highlights the complexities of applying electrostatic principles in this scenario.
meteorologist1
Hi, I have no idea of how to do the following problem and what formulas I should use. Please help! Thank you.
A spherical balloon has a conductive coating and we propose to inflate the balloon to a diameter of 0.1 meters by connecting the surface to a high voltage source. Suppose that the maximum practical electric field at the surface is 2 x 10^6 volts/meter (in air, just before breakdown of air molecules). What is the largest voltage we can apply, and what is the outward pressure (N/meters^2)? How many atmospheres is this?
Find the total charge Q on the sphere in terms of the electric field - gauss' law works here.
Then find the voltage on the surface of the sphere in terms of Q... plug in Q from the first part, to get the voltage.
Ok I understand the first part -- I can find the charge from Gauss's Law. For the second part, I'm still not sure what equation I should use. Should I use the equation W=QV or some other work equation? What about the outward pressure?
Ok when I try it: using 1) E = kq/r^2 and 2) V = kq/r, I get V = Er = (2 x 10^6 volts/m)(0.1 m) = 2 x 10^-7 volts. This procedure looks too simple. Is it right?
Yes, those two formulas work because of the symmetry involved. But r=0.05m, so V=Er=2*10^6*0.05=100,000V.
I'm not sure about the pressure part... if Force on a small area dA is F=(sigma*dA)E (where sigma is charge density)... And then you can find pressure by F/dA.
But using F=(sigma*dA)E seems wrong to me as the charges are located inside the conductor where electric field is zero... Not sure here. Sorry!
