Spherical Harmonics Homework: Calculate Coeficients & Express Function
pgerlein
Hi! I need help with this. I have to calculate the expression of a function using spherical harmonics. The relevant equations are given below. An example of a function can be f(theta,phi) = sin(theta)... Can you help me to calculate de coeficients and to express the function? Thanks.
View attachment formulas.doc
Hola pgerlein. Welcome to PF:smile:
Why don't you show us what you've tried for your example (f(\theta,\phi)=sin(\theta)) and we'll know how to help you better.
To make equation writing easier, this forum supports LaTeX. You can find an introduction to using it by clicking here
I can´t understand the use of this base (spherical harmonics). If I solve the ecuation that gives the coefficients value, how can I express the function in terms of the spherical harmonics?
How would you express a function in terms of a Fourier series, for example? Essentially it's the same idea when you write any function in terms of an infinite series of basis functions.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
