Spontaneous Energy Loss in Light
65 replies · 13K views · last reply
Hello Wimms, just saw your post. Only time for a quick answer. You replied to this frome me:
[[... "does the frequency really decrease as space
expands" and yes indeed it does. The frequencies in the
CMBR have declined by a factor of 1000.
Space stretching out makes their wavelengths longer and
that lowers their frequency by the same factor. Space
has expanded by a factor of 1000 since those photons were emitted and so their wavelengths are 1000 times longer and
their frequencies correspondingly lower.]]
In your reply you said:
Originally posted by wimms
Wait, just only 1000 times?? 13billion lightyears radius that was once singularity, expanded just 1000 times?
And, if even photon looses energy due to expansion, then anything should loose energy to expansion. Or, even, which is first, expansion causing loss of energy, or loss (dissipation) of energy causing expansion?
Since big bang there has been FAR more expansion than merely by a factor of 1100-----the factor for the CMBR.
The expansion has been by factor of 1100 since the epoch called "last scattering" or "recombination" which is when those CMB photons are thought to have been emitted.
The picture is of a clearing fog (actually hot plasma).
Above a certain temperature hydrogen gas is opaque, like the sun is opaque, because it is ionized into glowing plasma and is highly reactive with light. The electrons absorb and re-emit photons frantically.
Then as the plasma cools it suddenly becomes transparent because the neutral atoms form----no more free electrons.
The moment it becomes transparent, the photons are set free and fly essentially forever.
This cooling and transparency was reached at year 300 thousand, approx. This is the moment of origin of the CMB.
Matter behaves differently from light, in expansion. Matter too has an energy density (its mass-energy) but this falls off only as the cube------the energy simply spreads out into larger volume.
But light energy falls off as the fourth power. Because not only do there get to be fewer photons per volume but also each photon has its wavelength stretched out. This differential in the decline has an interesting effect. It changes the relative importance of matter versus light over time.
You ask which came first. The conventional view is that the expansion is a give and that the loss in CMB energy is simply one consequence of that.
Good question, thanks!
Originally posted by marcus
And you replied to that, asking for a reference.
Ned Wright's tutorial and cosmology FAQ are the easiest places to begin, probably.
Thanks, I found them and will read them today.
The frequencies in the CMBR have declined by a factor of 1000. Space stretching out makes their wavelengths longer and
I've been known to question someone into a headache, so let me know when you've had enough. But . . .
If the expansion of space is lengthening radiation's wavelengths, doesn't this mean "space" and light are interconnected somehow? I have myself wondered if they might even be the same thing, with light simply an accentuated form of space. If space were in reality, say, some sort of polarized field that had constricted and then released to generate the big bang, and light is a ripple in that field, that might account for light's (and everything else's) polar nature, inflation, and the stretching of wavelengths as space expands.
Great! If anybody knows some other online cosmology tutorial---entry-level like this one----and similar FAQ please post the URL!
Here's a helpful animation Wright has:
http://www.astro.ucla.edu/~wright/Balloon2.html
The photons start out blue and as space expands they get longerwavelength and they turn red.
And then as space recontracts they turn shorterwavelength and are colored blue again---the coloring is just an artificial way of
diagramming the change. Neat animation---movie of the universe.
Wright's isn't perfect or complete. His professor salary and research grants pay him to do other kinds of work--his tutorial is volunteer work, labor-of-love.
someone could make it a lot better if they could get a grant just for the purpose of creating a great online (un-popularizing) introduction to cosmology.
Wright will leave you with various confusions and missing pieces of the puzzle but it is still a wonderful start!
Deep question. Perhaps everything is connected to space because it HAPPENS in space. Space is, I guess, sort of defined by all the geometric relations between things.
In particular, the propagation of light is connected to space because it happens in that arena----no need for extra rubberbands or little wires to interconnect the two any further. IMHO. :smile:
Thought experiment: You and I discover an experimental place outside the universe where space is not expanding. We take a laser there and measure how far a flash of light can travel in a year. Maybe we put a mirror out a ways and have the pulse
fly to the mirror and back. We see that the pulse comes back with the same frequency and wavelegth it started out with.
Then we return to our real universe and set up the experiment putting the mirror intially the same distance away. what do we see? Does the pulse take longer to return? Is its wavelength lengthened when it gets back? If so how did that happen?
This is only a thought experiment because the expansion of space on a timescale of a year is way too slight to observe!
I do know that if space were eventually to begin contracting (as it does in some models) then the CMB which is now so cold would get so hot after a while that it would burn us up. It would go from present long-wavelength photons back to short wavelength sort of like sunlight, some even visible light, some infrared, some UV etc. Maybe this is a good picture of how expanding and contracting space changes the wavelengths of CMB photons.
Have fun. I cannot answer all the questions that you come up with, by a long shot! But they so far cause no sign of headache.
I think you better get your aspirin ready. :wink:
I have a couple of more questions . . . I'll do the easy one first. I read Linder's FAQs first since it was shortest, and in it he brought up something I have been curious about. He says:
"What is meant by the edge of the universe where velocities reach the speed of light? There are a number of concepts put together in this question. By edge of the universe cosmologists mean the edge of the observable universe or the horizon. Just like on Earth the fact that you cannot see past the horizon doesn't mean there's nothing past there! (See the next question for more details.) This edge is equivalent to the distance light can travel in a time equal to the age of the universe."
Although he says what the edge means, he doesn't say what constitutes the edge. In other words, is the edge considered the the furthest reaches of matter (i.e., stars, nebula, etc.)? Or does it refer to how far light might have traveled beyond the matter it radiated from? If the edge is determined by the expansion of matter, could it be that any of it reaches the velocity of light? Finally, if it is light, then is light creating space? Or is space seen as expanding ahead of or with matter and/or light?
I understand this is the prevalent view, but it doesn't make sense to me (I also know that a lot of things in physics are counter-intuitive but nonetheless true).
It doesn't make sense because of the mainly inviolable team of cause and effect. In virtually every other situation where an action consistantly results in a specific effect, we assume there is a relationship between the two. So, if space expands and EM's wavelength consequently stretches, that normally would mean there is some sort of causal relationship between the two. Right? Of course, it could be that aging EM would stretch whether or not the universe expands, but then we are back to the tired light theory. That is why I have thought space may be the whole ball of wax -- light, gravity, energy, expansion, matter -- all of it manifested potentials of a polarized field we call "space."
fly to the mirror and back. We see that the pulse comes back with the same frequency and wavelength it started out with.
Well, according to what I understand about light speed, it should take the same amount of time for the pulse to return (assuming both pulses traveled in a vacuum), but according to what you are saying about light and expansion, the pulse inside the universe should return lengthened because during its travels the universe was expanding. As for how it happens, I don't know, but I do have my little theory I mentioned above.
Sleeth, Alexander's "tired light" idea is totally wacko!
Do not listen to him. He only seems to want to argue and
believe himself to be right.
Markus, please apologise for associating this idea with me.
As you can clearly see from my post about "tired light" it was to show you that YOUR idea of "stretched photons" is wrong (as you said - totally wacko).
So, apologise for putting words I did NOT say in my mouth, ok? And don't do that again. PF is not the right place for personal attacks.
I rarely read your posts but my impression is that whenever I do I am likely to find an error. If I remember correctly:
1. you invoked a global energy conservation law in Gen.Rel. and there is no such law.
2. you claimed the energy lost from CMB went into gravitational energy!
3. you claimed there could be no voltage difference between the wingtips of a plane flying thru vertical magnetic field
4. I believe you also made false assertions about the Hubble law and limitations of recession speed in GR, but I would have to look back to check.
In every thread I can remember where I've had occasion to read your posts, you have made errors and when you are wrong you tend keep adamantly reasserting the false claim.
My views are standard mainstream views. The cosmological redshift is not Doppler. Maybe in Russia or wherever you are words are used differently and it is called "Doppler" and that means something else. But the simplest explanation is that you are just eccentric and opinionated.
I am glad to hear you disavow the "tired light" notion!
Tell me your interpretation of the Hubble law v = H0 D.
In what metric is the distance D measured? At what moment in time? The speed v is the change in what measure of distance?
At what time is the v considered to be measured?
This would be a good test of whether your understanding of what these things mean is an eccentric abberation on your part.
I read Linder's FAQs . . . in it he brought up something I have been curious about. He says:
Although he says what the edge means, he doesn't say what constitutes the edge. In other words, is the edge [of the universe] considered the the furthest reaches of matter (i.e., stars, nebula, etc.)? Or does it refer to how far light might have traveled beyond the matter it radiated from? If the edge is determined by the expansion of matter, could it be that any of it reaches the velocity of light? Finally, if it is light, then is light creating space? Or is space seen as expanding ahead of or with matter and/or light?
Anyone care to answer?
The visible edge of universe is just an expression. It has no physical "edge" meaning. Universe is same here, there (near "vision edge") and beyond the edge.
Main cosmological principle is Copernicus principle: our location in space is no special than any other. By other words, universe is spatially symmetric. This imposes severe limitations on mathematically possible "designs" of universe (cosmological models). Say, that positively curved universe shall not have boundaries, but nevertheless shall have finite volume and finite size. Negative or zero curved universe shall be infinite in size and in volume.
So, we live right at the edge of universe for observer(s) 13 billion light years away.
Sleeth I read Linder's FAQ and was shocked.
I like his Cosmology overview very much and admire him
both as a writer and researcher.
His Introduction to Cosmology may be a good textbook too, I haven't looked.
The FAQ was to an unmathematical lay audience and talked down a lot. Some of what he said, presumably in order to be understood, he simply should not have said.
There is a split between how cosmologists talk among themselves and what you get in popular accounts.
Within the community and with students they use the RW metric also called the FRW metric and a rest frame defined by the Cosmic Microwave Background.
Distance is often expressed as a redshift, and there is a standard way to convert this to a "comoving" distance----essentially applying the metric to give a current distance to the object.
They typically don't use "light travel time" because it is not a workable spatial distance---applies to a mishmash of different epochs.
In the FAQ he was using light travel time distance because, I guess, most general audience listeners understand distance that way.
Linder's overview was great but I would just disregard his popular-audience FAQ. I'll try to elaborate on this later.
Here's a url for Linder's good overview and for Wright's online calculator which you can use in conjunction with Linder's overview:
http://www.astro.ucla.edu/~wright/CosmoCalc.html
hmmm I've mislaid the Linder URL have to go hunt it
Here it is
http://panisse.lbl.gov/~evlinder/lcos.pdf
I see that Alexander has just replied. He illustrates the
common misconception that the "cosmological horizon" is
currently 13 billion LY away.
that is talking in terms of light travel time.
In fact the current distance to the farthest objects we could possibly see is now 40 billion LY, in principle.
This is measured by observers at rest with respect to background, in the present, using the standard metric.
The most distant quasar that has actually been observed
is 28 billion LY away, at the present time.
the light from this quasar (observed in 2002 at redshift 6.4)
took 13 billion years to get to us----traveling through regions which were in various stages of expansion when the light came thru. And during that 13 billion years----the distance to the quasar expanded out to 28 billion LY.
Its current speed of recession is 2c. The speed of recession is the rate of change in the comoving distance---which is what plugs into the Hubble law.
Wrights tutorial is the most accessible source on this
Linder glosses over too much
It is actually pretty simple and also at the same time interesting.
Toss out Linder's FAQ and look at something real, like that quasar---Wright discusses it and provides some links which I can get if you want them.
The z = 6.4 tells the story.
You plug that into a calculator (Wright has on online) using
the current value of Hubble parameter and other standard assumptions which are inputs to the metric. And it gives you 28 billion LY as the distance.
That is the distance to the thing NOW
If you want to know the distance to it when the light was emitted you just divide by 6.4.
Because space has expanded that much since the light was emitted. 28/6.4 is 4.4
So the quasar was 4.4 billion LY away when the light left it.
The light took 13 billion years to come.
But the distance THEN was 4.4 and the distance NOW is 28 billion LY.
The 13 billion year travel time is not too useful because it doesn't immediately give a good idea of the distance either then or now.
Anyway, we can't see quasars which are currently 40 billion LY away. So far we have only seen one 28 billion LY away. But IN PRINCIPLE the distance to the horizon is 40 corresponding to infinite redshift.
The CMB is at redshift 1100. You can try that in the online calculator and it will, I guess, give pretty near 40, but not quite.
Because the CMB comes from a while after the big bang, so it is not quite at the horizon.
Hope you come back with more questions and are not boggled.
It is terrible when cosmologists use light travel time distance in talking down to people. Leaves a residue of confusion in how the public thinks.
Someone may have already answered me and I do not realize it, but I still haven't quite understood what is being relied on as the "edge." Is it matter only, or light?
But maybe I don't understand how light travels in our universe. If, say, the universe is considered flat and so its matter is spread out spherically, is light traveling just around that sphere, and not outwardly perpendicular to the sphere? It seems like the measurement of the universe is of distant objects like the quasar, but I then wonder if the light it emits isn't traveling beyond it "outwardly perpendicular" to the direction of expansion, and if so then should that be considered part of the size of the universe.
The other related question I have is about how fast matter is traveling in expansion. I thought I read that some galaxies are receeding at nearly the speed of light. Can matter so massive really go that fast? And are we ourselves moving as quickly away from other galaxies?
the current model is that space is flat, infinite, and expanding
(which means spacetime is not flat, but that is another issue)
There is a spherical volume in space called the observable universe (radius about 40 billion LY) which contains the objects which we can in principle observe
their light has reached us, of course we can only see them
as they were in the past when the light was emitted but
those are the object we know about and can observe
they are contained in a ball currently 40 billion LY in radius.
The surface or boundary of that ball is like a horizon
Maybe you could say it is an "edge" the way our ordinary
horizon on Earth is an edge. OK word, but maybe not the best word.
Does this help?
Does this help?
Yes, it is mostly what I thought.
Here's what is still unanswered for me:
1. Light diverges. So does radiation travel outward and away from the horizon (essentially increasing the circumference of the horizon)? If so, is that light considered the horizen, or is it only the furtherest expanded matter that determines the horizen?
2. I'll just repeat my other question, "The other related question I have is about how fast matter is traveling in expansion. I thought I read that some galaxies are receeding at nearly the speed of light. Can matter so massive really go that fast? And are we ourselves moving as quickly away from other galaxies?"
Thanks for your patience.
Whoah! I see the problem! No, space is not like the surface of a balloon!
When people say space is flat they mean like ordinary 3D Euclidean space where the sum of the angles in a triange is 180 degrees. It is the infinite 3D space we are used to. this is on a large scale. Overlooking local bumps caused by stars and black holes and stuff. There are minor local abberations from flatness but in the large it is just our usual 3D infinite space.
The difference is that it is expanding. So when you put time into the picture it is more complicated. But anyway as far as space, at anyone instant of time, goes----think of standard 3D coordinates going to infinity.
Inside this Euclidean 3D space there is a finite ball-shaped volume containing all the stuff that has been seen with telescopes so far. This ball gets larger as time goes on and more news comes in and light from farther away and longer ago arrives.
Recession speeds in cosmology are routinely faster than light.
This doesn't mean spaceships can go faster than light it just
has to be because you have an infinite thing expanding uniformly. If you look far enough out you are going to see stuff receeding
faster than light.
The Special Relativity coordinates don't apply on large scale
and the speed limit you get in SR does not apply either.
The recession speed is not like an ordinary SR speed
(could not be used for sending information or for rocket travel, is not local but is only a change in distance between widely separated points in space).
Have to go, can't finish the discussion but will get back later
Thx enormously for YOUR patience, not always easy for me to say things concisely.
YES we are going away from the other galaxies at speeds near and even exceeding the speed of light. The uniform expansion of infinite space requires this. If there are conscious beings in other galaxies they would think of us as receding. But it is not like rocketship travel---it is just space spreading out. No one is going anywhere, is some sense. Just separation increasing in some cases at 2c in some cases 3c and so on----all different speeds depending on how far away.
Have to postpone answer, busy. Be back
Good thinking. It works both ways
this spherical volume containing things we have seen also
can be thought of as the ball of space which our light has reached
or which light from our location could have reached if something here had been making light from the beginning.
Ned Wright, in one example, looks at it that way.
He is explaining why the radius of the observable universe is about 40 billion LY and why the boundary is receding at speed around 3c. I will try to find the page reference and give a link.
So it is the spherical volume containing things whose light has reached us and ALSO reciprocally the volume of where our light (if we had making it from the very start) would have reached.
Our galaxy didnt get started glowing exactly at the beginning, so its actual light hasnt quite reached that far, but that is the rough idea. It works both ways.
Yeah, here it is
http://www.astro.ucla.edu/~wright/cosmology_faq.html#DN
It is from Wright's Cosmology FAQ and is called
"If the Universe is only 10 billion years old, how can we see objects that are now 30 billion light years away?"
For easy numbers he is considering a Einstein de Sitter universe
(no extras) that is 10 billion years old
So he has the radius be 30 billion LY
Just as with a more realistic model with age something over 13 billion years
the radius is around 40 billion LY
He considers a galaxy out near the horizon and also
a photon of light passing that galaxy and heading outwards.
It could have been one emitted by us, if we had had a light on at the beginning.
He does a little arithmetic to let time pass a bit and then looks
at it again and the boundary has moved out and the photon is
right there keeping pace with it.
I think what you concluded intuitively is right and this calculation, tho simplified for easy numbers, confirms your intuition.
can be thought of as the ball of space which our light has reached or which light from our location could have reached if something here had been making light from the beginning.
Thank you for clearing that up. The reason I wondered is related to an additional question I've been pondering which is, what is creating "space"?
Some have said that the expansion of the universe creates space as it goes along; that before the space of our universe gets there, there is nothing at all. Our space seems not a void after all with virtual particles popping in and out, dark matter, and the possibility of a cosmological constant (and the theoretical Higgs field?). In other words, while space may be the absence of matter, it also may be dynamic in certain respects.
So, I wondered if as the universe expands, what exactly defines the creation of new space on the horizon. Is it the light traveling ahead of matter expansion creating it? Or could possibly the qualities of space itself be expanding just ahead of light and everything else, creating the potential for the rest to follow?
(Getting that headache yet? :smile: )
Hello Sleeth thanks for the new question, more to think about. But there was still a bit of grist for my mill in what you said earlier
Originally posted by LW Sleeth The other related question I have is about how fast matter is traveling in expansion. I thought I read that some galaxies are receeding at nearly the speed of light. Can matter so massive really go that fast?
[/B]
this is the most important question because it involves RECONCILING the local SR picture with the global GR picture.
It is easy for distant galaxies to be receding at twice the speed of light or more and it does not make them more massive. It is inevitable that some galaxies would be doing this because of the uniform expansion of space. Yet this does not contradict Special Relativity, which is about relative speeds of things at the same point in space or in the same locale.
The coordinates of SR are called "Minkowski" and Minkowski coordinates don't apply in the large. The Minkowski spacetime
of Special Relativity has no ability to expand. In the real universe you can only apply Minkowski coordinates in a small local region,
like a bandaid. There is no bandaid that covers the whole person.
No rocket ship could PASS THE EARTH going over the speed of light. Indeed in our local coordinates as things approach the speed of light their energy (measured in our local laboratory coordinates) grows unboundedly. They become harder and harder to speed up any further---taking more and more energy to get the next little bit of speed.
But that is no reason why a distant galaxy can't be just sitting still in the space around it and receding from us at twice the speed of light. Thousands of galaxies are doing just that. It does not contradict SR because it is not in our laboratory, or in the sun's neighborhood, or in our local Minkowski coordinates----however you want to say it.
We did not invest energy to accelerate those distant galaxies. They don't have any extra energy or mass just because they are sailing away at twice the speed of light. They have to, because space is expanding, and they are not in the same local SR Minkowski coordinte frame with us.
The distance to them is measured with a METRIC, the robertson walker metric which is able to deal with spacetime curvature and cope with expansion and do stuff which the rigid Special Relativity metric ("minkowski metric") cannot do.
So...different idea of distance...leading to different idea of speed...NO PROBLEMO! Galaxies receding at twice the speed of light and yet no weirdness like tachyons and going backwards in time and killing your grandfather and circus freak infinite energy stuff. All those things are stories told in a Special Relativity surround.
They recede at twice the speed of light and more because they are outside the purvue and jurisdiction of Special Relativity and there is no weirdness.
Now this is a REALLY interesting question. I will think a bit before answering. I think you would be satisfied if we just kept the DENSITY of mysteries like dark energy constant and space expanded.
If there is always the same amount of virtual X-particles PER CUBIC METER, then if your one cubic meter volume expands to be two cubic meters you now have twice as many virtual X-particles or "weirdons" or whatever. And twice as much of all the other familiar inhabitants of the vacuum as well.
That should be enough goodies for anybody. Let's not talk about space as if it were a commodity. If it expands and the per-volume quantity of all this mysterious stuff stays the same, then we get more goodies. the mystery remains, but phrased more acceptably IMHO.
It is definitely mysterious. 73 percent of the energy in the U is called "dark energy" and nobody has a convincing theory of what it is and it has never been detected. And the assumption is that the density of it is constant over space and time. So what makes more---to keep the density constant when space expands? [?]
It is one of the questions that make life worth living. I mean it.
Galaxies receding at twice the speed of light and yet no weirdness like tachyons and going backwards in time and killing your grandfather and circus freak infinite energy stuff. All those things are stories told in a Special Relativity surround. . . .
Now this is a REALLY interesting question. . . . It is definitely mysterious. 73 percent of the energy in the U is called "dark energy" and nobody has a convincing theory of what it is and it has never been detected. And the assumption is that the density of it is constant over space and time. So what makes more---to keep the density constant when space expands? [?]
Thanks for clarifying the speed thing . . . I can see why (I think) that expanding space causing recession faster than c isn't a problem.
This thread was really my round-about way of asking about the creation of space. I'd wondered if light moving ahead of matter expansion on the horizon might be doing it; and if so, and if light were losing energy over time, then if the integrity of new "space" might suffer too. You said that the light inside our universe is stretching and losing energy as it does, but I suppose that would not necessarily apply to the light leading expansion.
Yet apparently no one understands what is creating space. You seem resistant to instilling space with qualities, yet in addition to the other properties I mentioned it is powerful enough to move galaxies apart faster than the speed of light! That is why I suspect there is more to space than most seem to want to credit it with.
For example, usually it is said that acceleration or mass produces the gravity effect. But might not gravity be a property of space? That is, when there is a concentration of energy, such as the energy concentrated to accelerate or the huge amount of energy packed into matter, then that causes space to constrict. The higher the concentration of energy, the more the constriction.
The constancy of light speed too could be due to a certain tension space maintains of which light speed reflects. I always wondered why light and atoms oscillate rhythmically. A guitar string only does so, for instance, when it is under a certain degree of tension; without that minimum tension it flops around chaotically when plucked.
Both light speed and gravity could be the result of a single type of polarized tension of space, a divergent-convergent polarity. So when something reaches the density of light, the divergent side sends it off at light speed (rhythmically oscillating from the push-pull of the polarity), and when something exhibits more than that density, the convergent side kicks in constricting in on it.
These obviously are speculations of a "why" person; you can already tell I am not properly versed in the "how." I probably better cool it before a mentor transfers this thread to theory development!
Thanks for the interesting discussion so far. I am enjoying the heck out of it.
Les, first to clear one point up that, as I understand it, marcus doesn't quite explain right. No one or nothing is creating space. Spacetime itself is expanding as marcus said but one cubic meter prior to the expansion is still one cubic meter after expansion because the meter would expand with space. The way we measure the expansion is the red shift of the light emitted by galaxies far away. As it take millions of years, even billions of years for the light to get to us, a significant amount of expansion takes place. Also the further apart we are, the faster we recede from one another. As space expands the wavelength of the light also expands changing the period of the wave, the wavelength become longer, lower in frequency and thus red shifted. Some galaxies are so far away that the light from it has shifted beyound even infared to radiowaves and can only be detected by radio telescopes.
I've thought about your last question quite a bit lately. If the universe is expanding into dimensionlss, timeless space what would happen if a photo left our sace time and went into the void? I have no way of proving this and it is only speculation on my part but if it did happen then the photon would no longer have any velocity or momentum as V and M are meaningless in such a void or nul-space as I call it. If a photon or EM wave had no velocity it could no longer be a photon or EM wave and would instantly turn into matter, probably a string which is energy vibrating in a dimensional loop.
This would of cours be creating at least one dimension and that area of the void would no longer be dimensionless and therefore be spacetime. This would be creating spacetime in the sense that I think you mean. As I said this is pure speculation on my part.
Yes, that's pretty much how I see it -- I think it has been me that's used the word "create." A better term would probably be "determine," to describe what I'm asking. To me there seems to be a bit of a contradiction in the ambiguity in the definition of space.
If space is a void, then what is it expanding into? If someone says there is nothing there, not even space, then space is clearly of a different nature from nothing -- it is "something." It can serve as the medium for matter, for instance. Where matter isn't, seems to be what is being referred to as "nothing."
I've been trying to understand what makes space different from "nothing." As the universe expands, what exactly differentiates space from the nothing it is expanding into? Matter? But then, I wondered about the light going on ahead of it, does that determine the nothing has now become "space"? Or is more required, something else that is expanding along with light, that defines/determines space?
In a word, Dimensions. That is the difference between space and nothing or void or my nul-space. There are a number of people other than me who think that matter is what makes its spacetime. matter gane only exist in spacetime and if string theory is correct tthen matter in the form of strings is energy vibrating within a loop of a dimesion. Someone figured out that it would only take 28 dimensions to account for everything that exist. I think that the number is now down to 11.
One other thing about what I previously posted. It is speculated that while the universe is expanding it might still be a singularity or perhaps better a black hole. As such no photons could escape our universe and so no more space could be created.
This is about as far as I can go or the pain starts. I run into the same problem with Quantum Mechanics.
Hello Royce, Sleeth,
it seems a shame to quibble about one point---I like a lot of your speculation and agree with some of the background science you point to---but one of the hardest things to understand is that even tho on the large scale space is expanding the sizes of ATOMS don't grow.
Indeed in the picture of expansion cosmologists give us----*galaxies* don't get bigger they just get farther apart.
Even local clusters of galaxies can overcome expansion and stay together if they attract each other enough. A good cohesive cluster of galaxies falls back together and overcomes expansion. So it doesn't get disassembled. But that is a grey area---for the most part galaxies drift apart (but because within themselves they are securely gravitationally bound, they stay the same size)
the basic modules of life retain their integrity even tho largescale things drift apart
In fact if you see a photo of a redshift z=2 galaxy that means space has expanded by a factor of 1+z, or 3, since the light left it. And that galaxy is to all intents and purposes just a usual-looking thing. The expansion of space hasnt made US NOW significantly different from IT THEN. Other things may be different. But it is not smaller just on acount of living in an epoch when space hadnt expanded yet by that factor of 3.
We know not to worry about expansion effecting things on a local, solar system, or even Milky Way, scale.
And meters are not effected.
So a distance of a trillion meters, after space has expanded by a factor of two, becomes 2 trillion meters.
If atoms don't change size, then you wouldn't expect metersticks to change either----the size of our units of measurement is not linked to this largescale intergalactic distance expansion process.
Not to say I or anyone really understands this expansion---but simply that's how the prevailing model looks. Sorry if it seems inconsistent that only some things expand and other things dont---I realize the unintuitive aspect here.
Must go. Hope not too much of a ramble.
(of course just because a model happens to be the prevailing one at the time doesn't mean it is the ultimate truth! but still worth reporting I think)
must also add that there are people who
because of an observed speeding up of the expansion rate
have projected this acceleration hundreds of billions of
years---very far, don't remember---into the future and
come up with scenarios in which familiar entities like
galaxies are pulled apart
expansion becomes so rapid as to overcome their
integrity as gravitationally bound systems
their gravity is no longer able to fight it
and even worse, modules even smaller than galaxies are
pulled apart. I don't find these speculative scenarios interesting
or appealing
this is just a kind of linear projection taken to extremes
we don't know much about the dark energy responsible for
accelerated expansion---not enough to project how it will
be far in the future. pretty much pure speculation and not
to worry about
for the foreseeable future nothing of any consequence expands
except the largescale distances between galaxies and the wavelengths of the light traveling across those wide reaches of space. atoms and
metersticks stay the same size (paradoxically one might say)
if I have given a distorted picture perhaps someone else will
correct it.
galaxies are pulled apart . . . expansion becomes so rapid as to overcome their integrity as gravitationally bound systems
their gravity is no longer able to fight it . . . we don't know much about the dark energy responsible for accelerated expansion---not enough to project how it will be far in the future. pretty much pure speculation and not to worry about
Thank you Marcus and Royce for the thoughts and information.
In some threads I've seen people discuss the possiblity that the universe will expand forever. I always felt they overlooked the fact that the universe is also coming apart. It is expanding and radiating away, losing structural integrity. And possibly after some 10^50 years when most present protons should be taking a turn for the worse, the universe may become just someplace where it all used to be.
If we could travel ahead in time and observe this place, I wonder what there would be. Trying to imagine this is partially why I asked the question of this thread (i.e., if light spontaneously loses energy). I've wondered if we might not find a vast area something similar to cosmic background radiation.
It wouldn't quite be like background radiation however because it would be a lot more "stretched out" than it is now. That is, it would have lost virtually all its energy and so have elongated so much it would be oscillating far too subtly for any equipment we currently have to detect.
Yeah, Les, total entropy. I've read other speculations about it. Eventually the universe would look like the COBE background. I find that hard to imagine. Wouldn't gravity keep cold chunks of rock held in place at least locally? I sure don't know.
No, meter stick is not expanding with space because e/m interaction (atoms holding meter stick) is independent of space expansion.
By the same reason a photon does not stretch with expansion of space, Marcus is wrong here, energy of photon conserves, thus frequency and wavelength too (in vacuum). Redshift of distant galaxis is just due to fact that they are moving away from us due to space expansion (Doppler shift due to coordinate transformation).
Royce, I certainly do admire your signature quote:wink:
>>As always with respect,
>>Royce
>>"If you find yourself arguing with a fool, then the chances are
>> that he is doing the same thing."
