Spring and Damper system for viabrations
The discussion focuses on addressing vibration effects caused by two servo motors moving 75 KG masses on a granite countertop. Participants suggest measuring vibrations using accelerometers to gather data. They emphasize the importance of clarifying the specific "vibration effects" of interest for more targeted assistance. Additionally, providing diagrams or photos of the setup is recommended to better illustrate the problem. Understanding the system as a "spring-mass-damper" model is crucial for effective analysis.
printz0r
Hi,
This is a real life problem I am trying to find vibration effects.
I have 2 servo motors constantly going back and forth on a granite countertop. The two servo motors are moving two 75 KG masses.
I am trying to solve for the vibration effects that will happen on the granite countertop and all I read about is mass damper systems.
Is there a spring and damper value that I should assign to the granite table?
How do I solve the problem?
printzOr, So you want to find “the vibration effects that will happen”! I cannot tell you how to predict (solve) for them.
You might consider measuring the vibrations of the granite countertop with accelerometers, for example.
Cheers,
Bobbywhy
You need to explain what "vibration effects" you are interested in, before you will get much useful help here. Some diagrams or photos of the setup might be useful to explain what the problem is.
Vibration studies are accomplished by modeling systems as "spring-mass-dampers." However it is vital to provide a diagram of your setup to see exactly what your talking about.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
11K
