Spring constant k, car to rest
To determine the spring constant k for a spring that brings a 1440 kg car to rest from 111 km/h with a maximum acceleration of 5g, the calculations involve several physics equations. The maximum force exerted by the spring is calculated as F = ma, yielding 70560 N. The displacement x can be derived from the equation v² = v(initial)² + 2a(x), resulting in approximately 9.7 m. However, the force exerted by the spring varies with displacement, necessitating the use of average acceleration to find the maximum deflection. Ultimately, the relationship between kinetic energy and potential energy in the spring leads to the equation mv² = k d², which is essential for solving for k and d.
len2
What should be the spring constant k of a spring designed to bring a 1440 kg car to rest from a speed of 111 km/h so that the occupants undergo a maximum acceleration of 5.0 g?
____N/m
F=-kx
F=ma
V2=v(initial)2 + 2a(x)
v=v(initial) + at
a=5 x 9.8 = 49
F= 1440 x 49 = 70560
x= 30.83^2 +2(-49)x = 9.7
F/x= k =70560/9.7 = 7274.23
Your reasoning looks correct. Is there a problem you were having or did you just need a check on your method?
____N/m
F=-kx
F=ma
v=v(initial) + at
a=5 x 9.8 = 49
This is mostly correct, however the equation vfinal2 = vinitial2 + 2ax is based upon the acceleration (or deceleration) a being constant over distance x. In the case of a spring the force F is proportional to the deflection, F = kx, so the F and the resulting acceleration will vary with distance,
F = ma = kx or a = (k/m)x.
The maximum acceleration occurs at maximum deflection, and in this problem the maximum or limiting acceleration is 5g (or ~ 49 m/s2).
There are two parameters which one must find in this problem, one is the spring constant and the other is the maximum deflection which is not given. One needs two 'independent' equations to solve for two parameters.
Now to finish the problem, find the 'average' acceleration which gives 0 for x=0, and 5g for x = d, where d is the maximum or total displacement of the spring. So, if a(x) = 0, and a(d) = 5g, and a is linear in x, then the average a is just the arithmetic average <a> = 5g/2, or the average a = <a> = amax/2. Then one can use
vfinal2 = vinitial2 + 2ad, where d is the distance over which the average a is applied.
or realizing the previous equation is a form of the conservation of energy, one can realize that the initial kinetic energy of the car must be transformed into the mechanical potential energy stored in the spring at full deflection, i.e.
1/2 mv2 = 1/2 k d2, or
mv2 = k d2.
Using Fmax = m amax = k d, find d and substitute it into the other equation.
Here is a handy reference - http://hyperphysics.phy-astr.gsu.edu/hbase/mot.html
http://hyperphysics.phy-astr.gsu.edu/hbase/acons.html
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
