How Do You Calculate Spring Constant and Package Weight?
In summary, the conversation discusses a problem involving a spring with a pointer attached and three different packages hung from it. The question is which mark on the scale will the pointer indicate when no package is hung, and what is the weight of the third package. The solution involves a formula and the answers are 23 mm and 45 N respectively.
queenspublic
59
1. Problem
A spring with a pointer attached is hanging next to a scale marked in millimeters. Three different packages are hung from the spring, in turn, as shown below.
(a) Which mark on the scale will the pointer indicate when no package is hung from the spring?
(a) ? mm
(b) What is the weight W of the third package?
(b) ? N
2. Attempt at a solution
240 N - 110 N = 130 N
60 mm - 40 mm = 20 mm
130 N = -k * 20 mm <-- Is this formula correct? If not, how do I find the answers to (a) and (b)?
k = -6.5
Never mind. I found the answers.
(a) 23 mm
(b) 45 N
Thanks for nothing. lol.
N/mm
To find the answers to (a) and (b), we need to use the formula for the spring constant, which is
k = F/x, where k is the spring constant, F is the force applied to the spring, and x is the displacement of the spring.
For part (a), when no package is hung from the spring, the force applied (F) is zero and the displacement (x) is also zero. Therefore, the spring constant (k) is also zero. This means that the pointer will indicate zero millimeters on the scale.
For part (b), we need to use the formula k = F/x to find the spring constant. Since we are given the displacement (x) of 20 mm and the weight of the third package (W) is unknown, we rearrange the formula to solve for W:
W = k * x
Substituting in the value of the spring constant (k = -6.5 N/mm) and the displacement (x = 20 mm), we get:
W = -6.5 N/mm * 20 mm = -130 N
Therefore, the weight of the third package is -130 N or 130 N downwards.
What is a spring constant?
A spring constant is a measure of the stiffness of a spring, or how much force is needed to stretch or compress the spring by a certain distance. It is represented by the letter k and is measured in units of force per distance, such as N/m or lb/in.
How is spring constant calculated?
The spring constant can be calculated by dividing the force applied to the spring by the displacement of the spring from its original position. This can be represented by the equation k = F/x, where k is the spring constant, F is the force applied, and x is the displacement.
Why is spring constant important?
Spring constant is important because it allows us to predict how a spring will behave under different forces and displacements. It is also a crucial factor in many real-world applications, such as in the design of springs for suspension systems or in the calibration of instruments that use springs.
Can the spring constant change?
Yes, the spring constant can change depending on the material, size, and shape of the spring. It can also vary if the spring is stretched or compressed beyond its elastic limit, causing it to permanently deform and alter its spring constant.
How does temperature affect spring constant?
Temperature can affect spring constant by changing the material properties of the spring. In general, an increase in temperature can cause the spring to become less stiff, resulting in a decrease in its spring constant. This is due to the thermal expansion of the material, which causes the molecules to vibrate more and reduces the force required to stretch the spring.
