How Do You Calculate the Initial Compression of a Spring in a Launcher?
  • Thread starter Thread starter tobywashere
    Launcher Spring
To calculate the initial compression of a spring in a launcher, the relationship between elastic potential energy and kinetic energy is crucial, with the equation 0.5kx² = 0.5mv₀² indicating that the potential energy stored in the spring translates into kinetic energy upon launch. The horizontal distance (Δd) and vertical height (Δy) to the target must be accurately defined, as they influence the time of flight and the trajectory of the spring. A detailed understanding of the spring's center of mass and its deformation during launch is essential for precise calculations. The final equation derived for the distance to pull back the spring incorporates variables such as mass, spring constant, angle of launch, and target distances. Accurate measurements and a clear diagram of the launcher setup can significantly enhance the precision of the calculations.
tobywashere
A spring is fired from a launcher angled Θ degrees from the floor. The spring has force constant k and mass M. The target is Δd metres away from the launcher and the target is elevated Δy metres. When the spring is launched, it travels at initial speed v0 towards the target, Θ degrees from the horizontal. The acceleration due to gravity is g = -9.8 m/s2. What is the distance the spring needs to be pulled back, x?
t = time
x = deformation of spring
Ee = 0.5kx2
Ek = 0.5mv02
Δy = (t)(v0)(sinΘ) + 0.5(g)(t2)
Δd = (v0)(cosΘ)(t)
I just need someone to check my calculations. I need to figure out how far to pull back the spring based on a given angle, and a given horizontal distance and vertical distance to the target. There are no specific numbers, I just need a general equation.
The elastic potential energy in the spring is approximately equal to the kinetic energy the spring has after the launch. Air resistance and friction are negligible.
Therefore, 0.5kx2 =0.5mv02
kx2 = mv02
v02 = (kx2) / m
Rearranging Δd = (v0)(cosΘ)(t)
t = (Δd) / (v0 cosΘ)
Substitute t into Δy = (t)(v0)(sinΘ) + 0.5(g)(t2)
Δy = (Δdv0sinΘ/v0cosΘ)(v0)(sinΘ) + 0.5(g)(Δd/v0cosΘ)2
Δy = ΔdtanΘ + (gΔd2)/(2v02cos2Θ)
Δy - ΔdtanΘ = (gΔd2)/(2v02cos2Θ)
2v02cos2Θ = (gΔd2)/(Δy - ΔdtanΘ)
v02 = (gΔd2)/(2Δycos2Θ-2ΔdsinΘcosΘ)
v02 = (gΔd2)/(2Δycos2Θ-Δdsin2Θ)
Substitute v02 = (kx2) / m
(kx2) / m = (gΔd2)/(2Δycos2Θ-Δdsin2Θ)
x2 = (gΔd2m)/(2kΔycos2Θ-Δdksin2Θ)
x = √(gΔd2m)/(2kΔycos2Θ-Δdksin2Θ)
bummmppppp
what type of physics course is it?
just wondering
senior high school physics
AP physics?
Nope. Just normal physics. But I'm self-studying for the AP physics exam. We were assigned a project to build a spring launcher. The teacher places a target somewhere, specifies the height and the distance, and also specifies the angle of launch. The point of the project is to hit the target. Right now I'm working on the equation to calculate the distance I need to pull the spring back.
What part of the launcher? The top of the launcher? And if so how is the top of the launcher defined? What is the length of the spring at equilibrium?
Or is the distance Δd defined as the spring's center, after the spring is already compressed?
If you wish to be precise, the geometry is important here. If the launcher and target do not move, the spring's total distance to the target changes as the spring is compressed (changes by some function of x). So it's important to precisely model how Δd, x, and the spring's total distance to the target (after compression) all fit together.
Δy meters with respect to the ground, the top of the launcher, the center of mass of the spring? It would help if you were more specific here.
A diagram would prove very useful.
I don't think that's a good assumption. Much of the initial potential energy remains in the massive spring, after the launch, in the form of internal oscillations.
(Without backing this up with any math, I did a quick and dirty calculation that came out as only about 1/2 of the original potential energy gets translated into the linear kinetic energy of the center of mass of the spring.)
[Edit: this assumes that the spring is not attached to any masses, and it is only the very spring itself that has a mass M.]
Just to clarify, the spring is the projectile.
"What part of the launcher? The top of the launcher? And if so how is the top of the launcher defined?"
The horizontal distance Δd from the target to the launcher is defined as the distance along the floor from the target to the base of the launcher (the launcher is always on the floor). This is in the x-direction only. The vertical distance Δy is the height of the target above the floor. Sometimes the target is elevated, sometimes it isn't. In the diagram, the target isn't elevated.
"What is the length of the spring at equilibrium?"
The length of the spring at equilibrium is 7.5 cm, but this shouldn't matter. All that matter is x, which is the amount of deformation.
The distance from the spring to the target doesn't change as the spring is pulled back. The front of the spring stays stationary. The distance from the centre of mass of the spring to the target changes as the spring is deformed, but this small distance is negligible.
"I don't think that's a good assumption. Much of the initial potential energy remains in the massive spring, after the launch, in the form of internal oscillations."
So what would be your version of the modified equation to figure out the distance to pull the spring back in terms of Δd, mass of the spring, Δy, k spring constant, and theta, the angle of launch.
Okay, if you want to ignore the change in the center of mass' position due to deformation, I'm okay with that if you are. :smile: It will make the math easier.
But before I let it drop, I just want you to realize that you are introducing a source of error into the math by doing so. Even in perfect conditions (ideal springs, launched in a vacuum, etc), it will cause the spring to be off target by an amount comparable to x (it also depends on Θ too). So if you calculate that x should be 4 cm, don't be surprised if the spring misses its target by a couple cm or so, even in the best of conditions.
But what you do need to do is estimate the spring's approximate center of mass in relation to the dot on the floor indicating where the base of the launcher is supposed to go. You need to find this displacement, in both the horizontal and vertical directions. Perhaps you can estimate this once, and use the same value for all launches. But you should at least measure it once.
All of the kinematics equations need to relate to the spring's center of mass. So you should have at least a rough idea of where it is in relation to the target.
What you are given is the displacement between the target and the base of the launcher. You will need to do is convert this to the displacement between the target and the spring's approximate center of mass. You can fit all this right into your spring stretching equation.
Well, I can't just give you the equation, but I can help you figure it out. :cool:
If instead of a massive spring, you were to launch a mass from the end of an ideal mass-less spring, 100% of the spring's potential energy would end up as the mass's kinetic energy. So let's model the massive spring by approximating it as a mass and separate mass-less spring combination.
Consider a mass-less spring of spring constant k. Break the spring into two equal pieces, and glue a point mass M, right in the middle.
When you break a spring in half, the spring constant is approximately double what the original spring constant was. So let's call this new sub-spring constant j
j = 2 k
Now let's go back to two sub-spring system with the mass in the middle. Imagine compressing (or stretching) the entire thing by the amount x. How far does the mass in the middle move?
Let's call this displacement of the mass in the middle z,
z = ½ x
Once compressed (or stretched), and immediately after being released, we can ignore the sub-spring that's no longer pushing or pulling on the mass. Only one of the sub-springs make a difference anymore. So the total potential energy, that will end up getting converted to the mass's kinetic energy, is,
E = ½ j z2
How does this energy relate to k and x?
(And if you're wondering where the rest of the energy went, it went into the other sub-spring that we can ignore for this. You can think of it as the internal oscillation part if you want to. But it doesn't affect the center of mass.)
Alright that helped a lot. So, the new equation would be
x = √ [(2gΔd2m) / (2k(y2-0.3sinΘ)cos2Θ-Δdksin2Θ)]
By the way, the length of the launcher platform is 30 cm, so the original height of the spring above the floor would be 0.3sinΘ. And your suggestions about the elastic potential energy and kinetic energy altered the equation by a factor of root 2.
This means that, if I plug in mass of spring, horizontal displacement, spring constant, vertical displacement, and angle theta, I will get the distance I should pull back? And if I pull the spring back by that amount, it would hit the target?
Hello tobywashere,
I have a few separate comments on your new equation, based on the equation that I came up with. I'll take them one at a time.
Looking at the diagram that you posted a couple of posts ago, the main part of the height of the spring above the floor comes from the vertical rod that attaches the base of the launcher to the pivot point of the platform. This isn't expressed in your "0.3sinΘ" expression, that I can see. Unless that's what you mean by y2. You should be okay if y2 = y - h, where h is the height of this vertical rod. (See more below on this in the next section.)
But are you sure you want to use the entire length of the vertical rod for the 0.3 in the 0.3sinΘ? What you're interested in the distance from the pivot point to the distance to the approximate center of mass of the spring. I can't tell what this is without a better diagram or description of the launcher. I just want you to be careful on this.
Drawing a detailed diagram of the launcher, and calculating the height from that might be better.
(And it might turn out that the difference in height of the spring due to the tilt Θ, is small enough to ignore. I mean we're already making a few approximations anyway. But that really depends on the design of the launcher, and how much error is acceptable.)
The order of the above terms in red seem to be switched around. It's difficult for me to interpret it, since it's not clear to me exactly what y2 is. But I'm going to assume that as the height of the target get's higher, y2 gets larger (i.e. more positive). In that case, the two are switched around. Let me explain,
Right now you have something in the form
(y - h0),​
but it should be of the form
(h0 - y).​
where h0 is the initial height of the spring above the ground.
Consider the case where Θ = 0. Making the correction (and substitutions), the equation simplifies to:
x = √[(2gd2m)/(2k(h0 - y))]​
which makes sense. If Θ = 0, the target better be below the initial height of the spring, otherwise, no value of x will ever cause the spring to hit the target.
But in your equation, the value of x will be an imaginary number, unless y2 is large and positive. That doesn't make much sense to me. What should happen is that x becomes imagnary if y is too large and positive.
Or if instead of switching them around, you could put a negative sign on the whole term. But one way or another something doesn't look right with the negative signs.
Don't you mean sin(2Θ)? :smile:
Sounds reasonable.
That's the idea, yes. You're equation needs a touch of work, but yes. Once your equation is finished, you can just plug the numbers in and it should give you the x that will cause the spring to hit the target (within a reasonable amount of error).
[Edit: corrected a couple typo mistakes.]
Thanks for all your help!
Below is a better diagram. Basically, the launcher is a flat piece of wood that hinges relative to the floor. There is no vertical rod. Therefore, the height of the spring is approximately 0.3sinΘ.
Also, y2 is the height of the target above the floor, which is the final height of the spring projectile. The expression is Δy = y2 - 0.3sinΘ, which I used to replace Δy in the equation. In the case that the target is on the floor and below the spring, Δy would be negative. In the case that the target is elevated and above the spring, Δy would be positive.
The launcher platform is quite long, so the height due to the tilt should be considered.
The launcher is always on the floor. Only the target gets elevated. Looking at the equation, the numerator, 2gd2m, is always negative because g is negative. That means that the denominator also has to be negative to avoid imaginary numbers. The denominator can only be positive if y2 is very large and positive. But my teacher would never give me an angle and a target elevation that would be impossible to hit no matter how far I pull the spring back.
Okay, your description helps. That makes more sense to me now. So far so good. :approve:
But see my comments below about g
Regarding g.
The constant g, by convention, is always a positive 9.8... m s-2. If, for the specific problem at hand, you define your position, velocity and acceleration vectors pointing up, then the acceleration due to gravity is -g = -9.8 m s-2. But the value of the constant g itself is still positive!
In other words, depending on the problem at hand, feel free to put a negative sign in front of g, if the acceleration vector points in the opposite direction of gravity. But don't change the value of g itself!
Using this convention will save you immeasurable confusion in the future, such as a future college course is physics. The convention is that g is always positive. The acceleration itself isn't necessarily positive (such as -g); but the constant g itself is positive.
http://en.wikipedia.org/wiki/Standard_gravity"
I probably should have mentioned that earlier, since you indicated that in your original post, but I didn't really think about it then.
So your equation should work okay as it is if you (erroneously) define g as being negative, (except for the sin2Θ vs the sin(2Θ) difference). :approve:
But I suggest reworking the problem using a positive g from the beginning; particularly if you are going to show this equation to your instructor. Let me present you with an equation (that uses a positive g). What do you think of this?
x = \sqrt{\frac{2g(\Delta d)^2 m}{2 k (0.3 \sin \theta - y_2) \cos^2 \theta + \Delta dk \sin (2 \theta)}}
x = √[(2gΔd2m)/(2k(0.3sinΘ - y2)cos2Θ + Δdksin(2Θ))]
Do you think that will work? Does it match your version (with a positive g) or do you find any mistakes in it?
That's perfect. Thank you so much for your help. What do you do? Are you a physics teacher? Professor?
Nah. I'm just a bit loopy in the head is all. http://www.websmileys.com/sm/crazy/146.gif
Good luck on your project! http://www.websmileys.com/sm/happy/535.gif
One last thing. About your statement that only half of the elastic potential energy is eventually converted into kinetic energy. I asked my physics teacher and he didn't believe it. He said that he has been doing the project for years and all of his students have calculated that all of the elastic potential energy gets converted to kinetic energy. Are you absolutely sure? I can follow your line of reasoning, but my teacher isn't usually wrong.
Now that you mention it, I neglected to consider various types of springs. I never thought about this, but I had some assumptions in my mind about the spring being used, and I never considered other spring types besides what I was imagining.
The entire time, I was thinking that they spring to be launched was one that, starting from its equilibrium state, can be both stretched and compressed, while remaining in its linear region. I was also thinking that the spring had a very low internal damping coefficient, such that once it started to oscillate, it would keep going for awhile. Imagine a spring that can be squeezed together when a compressive force is applied, and can be pulled apart when a stretching force is applied.
(Image courtesy of this site: http://www.shutterstock.com/pic-23205412/stock-photo-metal-coil-on-isolated-white-background.html")
Consider a spring such as the one discussed above. Secure one end of the spring to a solid, immobile platform. Then either stretch it or compress it some distance x and let go. The spring will oscillate back and forth for some time. This is the energy which gets trapped in the oscillations that I was discussing earlier. So for a spring such as this, if launched from a launcher, I would guess that only roughly half the kinetic energy would end up as the kinetic energy in the center of mass.
On the other hand, I hadn't even considered springs that are already at or near their maximum compression at equilibrium! Imagine a spring, starting from equilibrium, that you can stretch apart, but cannot compress (at least not very much, before reaching saturation).
(Image courtesy of this site: http://www.shutterstock.com/pic-44966506/stock-photo-object-on-white-tool-metal-spring.html"
That type of spring might change the center-of-mass kinetic energy ratio significantly. Essentially, what happens is that each loop on the spring hit's the adjacent loop at the moment the entire spring fully collapses, and it ends up being one big inelastic collision.
I did some fairly detailed calculations regarding the ratio of kinetic energy after vs the total kinetic energy before. (Normally, I would not just give these calculations away to the original poster of a thread, but you mentioned that your instructor is already recommending using a given value; and besides my calculations are a bit beyond most high-school physics anyway.)
Here is my model. In this model we are only concerned with the inelastic collisions themselves, and kinetic energies before and after the collisions. Nothing so far deals with spring characteristics (more on the below). Springs are modeled by distributed masses. Suffice it to say, that all the spring's potential energy is converted to the mass's kinetic energies immediately before the collisions (kinetic energy is not conserved after the collision however).
  • Number of masses (loops): n
  • Mass of a each loop: m
  • Velocity of tail end of the spring, immediately before collision: v1
  • Velocity of all loops (whole spring), immediately after the collision: v2
//////// Two mass example. ////////
Consider a "spring" simply modeled by a mass at the tail end, and an equal mass in front (at rest) before the collision.
Conservation of momentum:
mv_1 + 0mv_1 = (2m)v_2
v_2 = \frac{1}{2}v_1
Kinetic energy comparison:
\mathrm{before} \ \Leftrightarrow \ \mathrm{after}
\frac{1}{2}mv_1^2 \ \Leftrightarrow \ \frac{1}{2}(2m) \left(\frac{1}{2}v_1 \right)^2
simplifying,
\frac{1}{2}mv_1^2 \ \Leftrightarrow \ \frac{1}{4}mv_1^2
\frac{(\mathrm{K.E. \ after})}{(\mathrm{K.E. \ before})} = \frac{1}{2}
//////// Three mass example. ////////
mv_1 + m\left( \frac{1}{2} v_1 \right) = (3m)v_2
\frac{1}{2}mv_1^2 + \frac{1}{2}m \left( \frac{1}{2}v_1 \right)^2 \Leftrightarrow \frac{1}{2}(3m) \left(\frac{1}{2}v_1 \right)^2
simplifying,
\frac{1}{2}mv_1^2 + \frac{1}{8}mv_1^2 \ \Leftrightarrow \ \frac{3}{8}mv_1^2
\frac{5}{8}mv_1^2 \ \Leftrightarrow \ \frac{3}{8}mv_1^2
\frac{(\mathrm{K.E. \ after})}{(\mathrm{K.E. \ before})} = \frac{3}{5}
//////// Four mass example. ////////
mv_1 + m\left( \frac{2}{3} v_1 \right) + m\left( \frac{1}{3} v_1 \right)= (4m)v_2
\frac{1}{2}mv_1^2 + \frac{1}{2}m \left( \frac{2}{3}v_1 \right)^2 + \frac{1}{2}m \left( \frac{1}{3}v_1 \right)^2 \ \Leftrightarrow \ \frac{1}{2}(4m) \left(\frac{1}{2}v_1 \right)^2
simplifying,
\frac{1}{2}mv_1^2 + \frac{1}{2}m\frac{4}{9}v_1^2 + \frac{1}{2}m\frac{1}{9}v_1^2 \ \Leftrightarrow \ \frac{1}{2}mv_1^2
\frac{7}{9}mv_1^2 \ \Leftrightarrow \ \frac{1}{2}mv_1^2
\frac{(\mathrm{K.E. \ after})}{(\mathrm{K.E. \ before})} = \frac{9}{14}
//////// n mass example. ////////
\sum_{j=1}^{n-1} \frac{mvj}{n-1} = nmv_2
simplifying,
\frac{nmv_1}{2} = nmv_2
Which is now shown to be true for all n.
\frac{1}{2} \sum_{j=1}^{n-1} \frac{k^2}{\left(n-1 \right)^2}mv_1^2<br /> \ \Leftrightarrow \<br /> \frac{n}{8}mv_1^2
simplifying,
\frac{1}{2}mv_1^2 \frac{n(2n-1)}{6(n-1)} \ \Leftrightarrow \ \frac{n}{8}mv_1^2
\frac{(\mathrm{K.E. \ after})}{(\mathrm{K.E. \ before})} = \frac{3(n-1)}{2(2n-1)}
\mathrm{maximum} \ \frac{(\mathrm{K.E. \ after})}{(\mathrm{K.E. \ before})}<br /> = \lim_{n \to \infty} \frac{3(n-1)}{2(2n-1)} = \frac{3}{4}
Here is the results: the spring's maximum final kinetic energy is at most 3/4 the original total potential energy (it is assumed that the springs original, total potential energy is completely converted to kinetic energy immediately before the collision [but not after]). The rest is doomed to be lost to heat (friction).
Remember, with the other type of spring (which is the ideally elastic version), I mentioned that only 1/2 the original energy gets transferred to the center-of-mass kinetic energy. With the new type of spring, you can bring that up to 3/4. But according to my math, you'll never get any more than that.
Special note regarding springs that are fully compressed at equilibrium:
Springs that are already fully compressed with no tension need to be treated a little differently. Hooke's law still applies, but it needs to be modified:
F = -k(x + x0); for x > 0.​
where x is measured at the point where the spring is fully compressed. The constant x0 cannot be measured directly, but it can be measured by hanging calibrated weights on the spring and measuring x; then determined either by graphing or solving a couple simultaneous equations. Your instructor should know how to do this.
If you don't account for x0, the potential energy stored in the spring might be underestimated.
Underestimating the potential energy stored in the spring, combined with overestimating the kinetic energy of the spring when it flies off the launcher (100% vs. 3/4) might together account for why nobody (even your instructor) ever noticed anything in past classes (I'm only speculating on that point).
Here is what I recommend moving forward.
  • Ask your instructor what type of spring is going to be used for this project. If it is a very elastic spring that can be stretched and compressed, I'd use 1/2 for the PE to bulk KE transfer. If it is a spring that is fully compressed at equilibrium, use 3/4.
  • Print out a copy of this post and give it to your instructor. I'd like him to take a look at it. Or at least point him to this thread on the Internet.
  • Once he's had a chance to look it over, let me know if he has any comments.
  • Once again, good luck! :smile:
My instructor isn't providing springs. The students are responsible for providing their own springs. The springs I'm using are identical to the springs in the second picture. The springs can't be compressed at equilibrium.
So I edited the equation assuming 3/4 of the elastic potential energy is converted into kinetic energy. I measured the k constant and the mass of the spring today. I tested the launcher out, and the equation proved to be surprisingly accurate. The launcher wasn't perfect, but there were many factors that could've caused inaccuracies.
I don't understand the part about applying hook's law to my type of spring. Isn't F = -k(x + x0) just the k constant times the change in the spring's length (deformation)?
I've attached the new equation and a picture of my launcher below.
Great! :smile:
The standard version of the Hooke's law, F = -kx, assumes that the spring is actually at its equilibrium point when x = 0.
Imagine for a moment, that you take one of your springs attach one end to a nail in a long board, and stretch the other end out a long way, say for an entire meter. And suppose that the spring doesn't break or plastic-ally deform (don't actually do this, by the way, you'll probably damage your spring in reality. I'm just speaking hypothetically here). But imagine you're really putting a good tug on it to get it that far. Now secure the free end to a second nail on the board. Now suppose you define the position of the second nail at position x = 0. Now suppose you grab the end again and attempt to stretch it by an additional millimeter. Should you expect that the force would be F = -k(0.001 m)? Of course not! :smile: The required force is going to be much closer to F = -k(1.001 m). More generally, the forces will be much closer to F = -k(x + 1.0 m). But even in this hypothetical situation, the true x0 might be a little larger than even 1.0 m, since the spring isn't necessarily at its true equilibrium point, even when the spring is fully collapsed.
Perform this test on one of your springs. Pick up the spring by one end and let it dangle by its own weight. *Gently* shake it up and down. Do the loops in the spring ever momentarily come apart when you do this, or are they always stuck together? Try shaking it up and down a little more vigorously. Do the loops still stay stuck together? If they still stay together, try something else. Place something delicate in the other ring, and use it to try and separate the individual rings, just enough so they barely come apart. Does it feel that the delicate object might bend or break before the rings start to separate?
If the rings move apart on their own in this experiment, then don't worry about x0. It's probably close enough to 0 such that you can ignore its effects. If so, you may as well skip most of the rest of this post, and go down to the next quote.
On the other hand, if the individual loops stay struck together under the spring's own force of gravity, even when shaking the spring, or trying to stretch it even a smidge with something delicate, you really, probably should measure x0, and revise your equations to include it. (You can also expect a slightly different value for k too, depending on how that was measured.)
Procedure for measuring x0.
Since this is your project, I'm not going to tell you everything. I am going to leave you with some calculations that you must do yourself. But I'll try to get you started.
A second thing to realize, is that if x0 is not zero, there is no way to determine the spring constant k accurately without performing multiple measurements. This whole time, you might have been using the wrong value for k!
(In this procedure, I'm going to start with my own approximations such as ignoring the weight of the spring itself, under the force of gravity.)
To perform this experiment, you will need calibrated weights, or some way to measure force precisely. Maybe you can get access to something like this from your physics instructor? All you really need is a couple objects of different masses, that will cause the spring to stretch different amounts when attached to the spring. But you will need access to a precise scale, such that you find their mass (weight). You will also need a ruler or measuring device to measure the distance x. You might be able to use your launcher itself for this!
  1. Attach one end of the spring to a secure nail or something (you might be able to use your launcher itself for this), such that the spring can hang vertically.
  2. Note the position of the other end of the spring. Define this as x = 0.
  3. Place a weight with a known mass, M1, on it on the other end of the spring. The weight should be large enough to cause the spring to at least stretch a little. Ensure the weight and spring are hanging vertically and are not held at an angle by some slope or something.
  4. Measure the displacement of the spring. We'll call this x1.
  5. Repeat the above with a different weight, of different known mass, M2. The difference in weight should be different enough such that the displacement is very different than x1 (However, if you have two identical weights, you can use one of them for the first measurement, and both of them for the second measurement!) We'll call this second displacement x2.
(For the most accurate results, one of the masses should be very light. It should be just heavy enough such that it causes a small displacement. The other mass should be considerably heavier, such that it causes a displacement equivalent to what you might expect for a medium to far away target when you actually use the launcher. Whatever the case, perhaps the most important this is that the masses [weights] must be measured very accurately and with good precision.)
Alternately, instead of using weights, you can also perform the tests using one of those tension scale things (I forgot what their actually called -- but you attach one end to to a string, cable, or string, pull on the other end, and it reads out the force). Whatever you have access to.
Using the above measurements, you can form the following equations (I'm assuming that all x, x0, x1 and x2 are measured as positive values):
-M1g = -k(x1 +x0)
-M2g = -k(x2 +x0)​
You already know the value of M1, M2, x1 and x2. You just measured those.
The unknowns are k and x0. You have two equations and two unknowns. I'll leave the rest up to you! :-p
Once you have your new values of k and x0, and if possible, you should probably double check the equation, using the same setup with,
-mg = -k(x + x0)​
using different masses, m, just to double check that everything works out.
Procedure for modifying your equation.
It goes without saying, that you'll have to use the new value for k. You can expect that k was pretty close to what it was before, but not necessarily identical.
You'll also have to redo your equation with a different equation for the total potential energy of the spring. Previous to this, you were using P.E. = ½kx2. That has to change a little now. The complete, total potential energy stored in the spring is now described by P.E. = ½k(x + x0)2. But wait, there's a little more to it. Not all of the potential energy is available for conversion to kinetic energy. As a matter of fact, some of the potential energy is stored int the spring right now, even as you read this, while the spring is just sitting there. That amount is P.E.unavailable = ½kx02. So the total available potential energy stored in the spring is:
Total available P.E. = ½k(x + x0)2 - ½kx02.​
And of course, that is before the P.E. to K.E. conversion is considered (the 3/4 value that we discussed previously).
From there I will leave it to you to modify your equation as appropriate.
Assuming no consideration of x0, your equation looks good to me. :approve:
Thanks for your insight. I did the experiment with five different weights, and these were the results:
I only considered the first four points
Δx (m) | F (N)
0.023 | 5.39
0.039 | 8.33
0.047 | 10.29
0.072 | 14.7
0.193 | 22.3
The way you suggested was to use a system of equations. However, I used a graphing calculator to graph these points and used a linear regression to find the equation of the line of best fit. The line fits quite closely. I only used the first four points because the last point deviates quite far from the line. The equation is y = 191x + 1.036
if F = k(x + x0)
F = kx + kx0
kx0 is a constant, equal to the y-intercept
On a graph of F vs deformation x, the slope is the value of k.
In this case, k is 191, and x0 is too small to be considered.
Therefore, I conclude that the above equation is correct with a k value of 191 N/m.
I did not consider the last point because the spring starts to deviate from hooke's law.
From my calculations, x0 is a little more than 0.5 cm.
I'd like to state now, that you've put a lot of effort into this project already, and the way it stands now, I can't imagine that you would receive anything except a very good grade for this project (I'm speculating that you will get an A). So modifying the equation to include x0 isn't so much about getting a solid grade anymore (I think you've already got that) but rather about having the best spring launcher possible, and maybe even one that breaks all-time school records for accuracy.
But here is a reason why you might want to modify your equation to include x0. x0 might not sound like much being only about 0.5 cm. But it can make a difference. By ignoring it, you are assuming that the total available potential energy of the spring is proportional to x2. But in reality, it might be more proportional to something around (x + 0.005)2 - 0.0052. For example, if x is 10 cm, you would calculate that the available potential energy is proportional to 102 = 100. But in reality, the available potential energy is proportional to 10.52 - 0.52 = 110. That's makes your potential energy approximation off by about 10%.
Go ahead and plug in some numbers and compare x2 with (x + x0)2 - x02, for typical values of x that you might actually use, and see if you think it's worth doing the extra math.
If you choose to modify your equation, here is how to go about doing it. Go back to the point where you had ½kx2 on one side of the equation (before you divided by ½k and took the square root). (And there might have also been a 3/4 factor involved too). Substitute ½kx2 with ½k(x + x0)2 - ½kx02. Now solve for x.
Ok here is the equation, edited once again.
The max distance that the spring is required to fire is 8 metres. Depending on the angle my teacher specifies, the value for x might exceed 19 cm, which is outside of the spring's hookean range. Would my accuracy be detrimented by the fact that the spring fails to obey hooke's law after a certain displacement?
Also should I use a k value of 191?
I could always go to the hardware store and buy a better spring.
'Looks reasonable to me. :approve:
Technically yes, it will have an impact. But modeling the nonlinear regions of the spring is probably way, way more than what your instructor wants you to do. And if you think your equation is getting pretty hairy now, it would get a lot worse when modeling nonlinearities.
You'll have to stop somewhere and put up with at least some approximations eventually. Otherwise you could keep making the equation so detailed that it needs a numerical solution on the computer to solve for x.
I mean we're already neglecting friction (other than the inelastic collisions in the spring itself) and air resistance. Some of the approximations you're making might actually compensate for other approximations (overestimating some things and underestimating others -- essentially canceling out some of the error).
I suggest testing your spring launcher and equation out! Test it at different angles and distances and see how well it does. If the equation proves to predict the necessary x accurately as it is, then that's about all you need to do. The proof is in the pudding.
I would suggest avoiding tests that require too long of x. If you stretch the spring out too much, it could cause the spring to go through plastic deformation, changing its k and x0 forever after. In other words, stretching your spring too far could ruin your spring (of course I guess you could substitute an identical spring after that if you had to).
I'm hoping that your instructor will not require extreme distances and extreme angles at the same time. Of course, you can ask him about that. It is an honest question, and if you tell him your concern he might give you an honest, specific answer.
But my point is, before considering the purchase of new springs, go ahead and test out your equation and existing spring at different angles and distances. If things seem to be working well, then you might as well keep what you have! :smile:
Hey! that's weird. I'm doing this same project in school.
How did you calculate x0 anyway? I did some more tests with hanging weights, I now I have more detailed information about the spring.
Deformation (cm) | Force (N)
2.3 | 5.39
3.9 | 8.33
4.7 | 10.29
7.2 | 14.7
8.0 | 15.19
11.0 | 20.58
13.9 | 25.48
16.5 | 30.87
Surprisingly, the spring obeys hooke's law quite well! I must've done a miscalculation in the last post, because one of the data points was quite off from the line of best fit.
I calculated the new k value, for the same spring, to be around 175 N/m. But how did you calculate x0? I tried to calculate x0 by dividing the x-intercept of the line by the k value, from which I got approximately 0.91 cm.
2.3 | 5.39
3.9 | 8.33
4.7 | 10.29
7.2 | 14.7
8.0 | 15.19
11.0 | 20.58
13.9 | 25.48
16.5 | 30.87
The assumption is that x = 0 is not quite at the equilibrium point of the spring. The equilibrium point of the spring is somewhere behind x = 0. Somewhere not accessible. The spring collapses at some point distance a little greater than the equilibrium point.
Which gives you
F = k(x + x0) = kx + kx0.
Now think about the equation for a line,
y = mx + b
You can solve for m and b as long as you have two points for (x,y). So go ahead and plug in two points and you can solve for k and x0.
