How Do You Calculate the Muzzle Velocity of a Spring-Loaded Toy Gun?
  • Thread starter Thread starter EvanQ
    Gun
To calculate the muzzle velocity of a spring-loaded toy gun, the conservation of energy principle is essential. The elastic potential energy stored in the spring when compressed is converted into kinetic energy as the ball is released. The correct formula to use is (1/2)kx^2 for the spring energy and (1/2)mv^2 for the kinetic energy, while accounting for gravitational potential energy. The final calculations reveal that the muzzle velocity, after correcting for gravitational effects, is approximately 5.72 m/s. Understanding the interplay of forces and energy transformations is crucial for accurate results in such physics problems.
EvanQ
A spring-loaded toy gun is used to shoot a ball of mass m= 1.50kg straight up in the air, as shown in the figure. The spring has spring constant k = 667N/m. If the spring is compressed a distance of 25.0 centimeters from its equilibrium position y=0 and then released, the ball reaches a maximum height h_max (measured from the equilibrium position of the spring). There is no air resistance, and the ball never touches the inside of the gun. Assume that all movement occurs in a straight line up and down along the y axis.
Find v_m the muzzle velocity of the ball (i.e., the velocity of the ball at the spring's equilibrium position y=0).
F = kx
F = ma
v^2 = u^2 + 2as
I think I am using some formula's that don't really belong. Not sure which steps I go wrong in though.
F=kx
=667x0.25
=166.75
F=ma
166.75=1.5a
a=111.16m/s
v^2 = u^2 + 2as
= 0+(2x111.16x0.25)
= 55.58
v = 7.455m/s
Several problems:
(1) F = kx gives the spring force at spring extension x, which changes as the ball moves. Plugging in x = 0.25 m only gives the force at one point.
(2) The spring tension is not the only force acting on the ball.
Hint: Use conservation of energy.
So potential energy = kinetic energy?
like:
kx = .5mv^2
667x0.25=.5(1.5)v^2
166.75=.75v^2
v^2=222.33
v=14.91m/s
elastic potential energy in the spring is (1/2)kx^2. You also need to consider gravitational potential energy.
Analyze the system at two points. At the bottom when the spring is compressed, and at the muzzle...
hmm ok.
Initially Ei = Ki + Ui = 0 + (Ugravity + Uspring)
= 0 + (0 + 1/2kx^2)
= (1/2)667 x .25^2
= 20.84375J
Final Ef = Kf + Uf = (1/2)mv^2 + (Ugravity + Uspring)
= (1/2)mv^2 + (mgh + 0)
= (1/2)(1.5)v^2 + (1.5x-9.8x0.25)
= .75v^2 - 3.675
Through conservation of energy:
Ei = Ef
20.84375 = .75v^2 - 3.675
24.51875 = .75v^2
v^2 = 32.69
v = 5.72m/s
bit confused as to what to use for h in the gravitational potential formula.
EvanQ said:
hmm ok.
= 0 + (0 + 1/2kx^2)
= (1/2)667 x .25^2
= 20.84375J
This part should be: = (1/2)(1.5)v^2 + (1.5x9.8x0.25)
so that will change your results.
other than that it all looks good to me.
You used h = 0 at the bottom where the spring was compressed. So the place where the spring is uncompressed (the equilibrium position y = 0)... h = 0.25, just as you did.
You could also have used h = -0.25 at the bottom, and h = 0 at the top. It doesn't matter as long as the difference in the heights is 0.25.
ok great thanks heaps.
got it correct, and finished off the next 3 questions which required that answer also.
cool. :smile: no prob.
similar question...
A toy gun uses a spring to project a 5.3 g soft rubber sphere. The spring constant k = 8.0 N m-1. The barrel of the gun is 15 cm long and there is a constant frictional force of 0.032 N between the barrel and the projectile. If the spring is compressed 5 cm what is the speed of the projectile from the barrel of the gun?
can do it using the same principles as above, just unsure on how to incorporate the friction force in instead of the potential gravity.
i tried using F=ma using the friction and mass of the projectile to get a deceleration, but then couldn't see how to put that in.
Basically the same idea except this time mechanical energy isn't conserved:
work done by friction = Final mechanical energy - initial mechanical energy
By mechanical energy I mean kinetic energy, gravitational potential energy and elastic potential energy...
remember that friction does negative work.
