Finding Spring Constant: Solving the Spring Problem
To find the spring constant for a block hanging from a spring, the problem involves a 1.60 kg block and an additional 0.4 kg mass that stretches the spring by 2.00 cm. The correct approach involves calculating the total force applied to the spring, which includes the weight of both masses. The initial calculation of k as 980 N/m was incorrect due to misunderstanding the total force acting on the spring. The realization that the total force is the sum of the weights of both masses clarified the solution. Understanding this concept is crucial for accurately determining the spring constant.
rileyjah
Spring problem!
A 1.60 kg block hangs from a spring. If a 400 g body is hung from the block, the spring is stretched 2.00 cm farther. What is the spring constant?
Fsp=-kdeltas
(2.0Kg)(9.8)/(0.02)=k
k-980 N/m... which is wrong
So I am assuming that at equilibrium with m1 x=0, and when the second mass is added the total displacement is delta s=0.02 m - what am I missing?
Are you really applying 2*9.8 Newtons of additional force to the spring?
Ohhhh! It makes sense now!
Thank you!
rileyjah said:
Thank you!
A pleasure :smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
