Solving Max Displacement of Spring with 5kg Block and Friction
The problem involves a 5 kg block connected to a spring with a stiffness constant of 49 N/m, initially stretched by 0.8 m. Upon release, the block will experience kinetic friction with a coefficient of 0.1, which will affect the maximum compression of the spring. The discussion emphasizes the importance of using conservation of energy principles while accounting for energy lost due to friction. Participants suggest starting with an equation for the total energy in the system and calculating the energy lost to friction to find the maximum compression. The analysis aims to determine how friction influences the spring's behavior after the block is released.
thecaksgood
block of mass m = 5 kg is connected to a spring having stiffness constant
k = 49 N/m, as shown in the figure below.
The surface between the block
and the table has μk = 0.1
In this figure, the block is presently held in place with the spring stretched
by x1 = 0.8 m. The block is then released. Determine the maximum amount
that the spring will compressed given that the coefficient of kinetic friction
between the block and the surface is μk = 0.1.
m= 5kg
k= 49 N/m
uk= .1 (friction)
spring= x1= .8m
Dis(spring)=?
Potential Energy
Kinetic Energy
I don't know where to begin
figure below?
This is a conservation of energy problem, but note that the frictional force will always retard the motion of the block (the compression of the block after it is released from rest must be lower than the maximum compression). This should be a good way to check your answer.
Try to start by writing down an equation for the total energy of the system, and determine how much of it is lost by friction.
