What Does a Spring Scale Read at Peak When Jumped On?
  • Thread starter Thread starter fender5791
    Scale Spring
When jumping on a spring scale from a height of 1.2 m, the scale will read a peak value based on the potential energy converted to kinetic energy. The spring constant (k) is calculated as 1.48 x 10^6 N/m, derived from the scale's compression of 0.50 mm at a weight of 740 N. The discussion suggests using the formula for kinetic and potential energy conservation to determine the peak reading. The key equation involves the spring potential energy, expressed as 1/2 kx^2. This approach provides a method to calculate the maximum force exerted on the scale upon impact.
fender5791
If you stand on a bathroom scale, the spring inside the scale compresses 0.50 mm, and it tells you your weight is 740 N. Now if you jump on the scale from a height of 1.2 m, what does the scale read at its peak?
I'm guessing you use 1/2kx^2 but otherwise, I'm not sure.
Welcome to PF!
Hi fender5791! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
ok, so what is the value of k? :smile:
(and yes, you can use 1/2 kx2 later)
So would k be (740N)/(.0005m) = 1.48x10^6 N/m?
Yup! :biggrin:
Now use KE + PE = constant.​
Got it, thanks.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
