What is Stack Up Tolerance Design for 2D?
  • Thread starter Thread starter rakea
    Design Tolerance
Stack up tolerance design for 2D involves analyzing and managing the cumulative effects of dimensional variations in two-dimensional designs. It is crucial for ensuring that parts fit together correctly within specified tolerances. The discussion highlights the importance of understanding these tolerances to avoid assembly issues. Participants are encouraged to clarify their specific questions regarding the topic for more targeted assistance. Overall, stack up tolerance design is essential for achieving precision in engineering and manufacturing processes.
rakea
Did anybody know stack up tolerance design for 2D??
Thanks a lot for your reference
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
