What is the Relationship Between Standard Position Angles and Acute Angles?
The discussion centers on determining the acute angle associated with the standard position angle of 12π/7. The standard position angle is found by noting that 12π/7 is in the fourth quadrant, leading to the reference angle calculation of 2π/7. The method for finding reference angles varies by quadrant, with specific formulas provided for each. The clarification of terms and the importance of understanding the quadrant in which the angle lies are emphasized. Overall, the relationship between standard position angles and acute angles is defined through reference angle calculations based on quadrant location.
sandynair
I have a question can someone help me?
If I want to determine the relates acute angle associated with each of the following standard pposition angles : 12/7 pi what is the answer and can someone show me as a drawing?
thanks
The "standard position" angle is between 0 and \pi/2 radians. 12/7= 1 and 5/7. Since 5/7 is larger than 1/2, the standard angle is \pi- (5/7)pi= (1- 5/7)\pi= (2/7)\pi.
The angle itself, drawn on an xy-coordinate system, is in the fourth quadrant, measured from the negative y-axis. The standard position is that same angle but in the first quadrant, measured from positive x-axis.
how is 12/7 = 1
It's not. He wrote 12/7 = 1 and 5/7, meaning 1 5/7.
Just to clarify, an angle in standard position is simply one whose vertex lies at the origin and whose initial side coincides with the positive x-axis. The terminal side of the angle can rotate clockwise or counterclockwise and lie in any quadrant.
The original poster was saying he was required to find the related acute angle (reference angle) associated with the following standard position angles (and he only listed 12pi/7 as one of these standard position angles).
The easiest way to find the reference angle for 12pi/7 is, once you know it terminates in the 4th quadrant (by noticing 12/7 is greater than 3/2), simply subtract 2pi - 12pi/7 and you will get 2pi/7.
As a general note, subtracting the measure of your quadrant four angle from 2pi is the way to get the reference angle for any standard position angle terminating in quadrant four.
For those that terminate in:
QI: ref angle = std. pos. angle
QII: ref angle = pi - (std. pos. angle)
QIII: ref angle = (std. pos. angle) - pi
QIV: ref angle = 2pi - (std. pos. angle)
Nice post.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
