Stargazing Star gazing with light pollution
Light pollution significantly affects stargazing, particularly in urban areas like Philadelphia and Harrisburg, where only a few stars are visible. However, a good telescope can enhance viewing capabilities, allowing for better observation of celestial bodies like the Moon, Jupiter, and Saturn despite the glare. The misconception that larger telescopes are less effective in cities is addressed in "The Urban Astronomer's Guide," highlighting that size can help compensate for light pollution. While deep sky objects are more challenging to observe, photography techniques can mitigate light pollution effects by adjusting brightness in editing software. Interestingly, temperature inversions in urban areas can sometimes lead to clearer views of planets.
Radrook
Guess this is for those who have a clear sky overhead. As it is the glare and pollution don't let more than a few stars shine through where I'm at.
Astronomy news on Phys.org
Where is that? Because I'm near Philadelphia and though the light pollution is pretty bad, a decent telescope will cut through it.
In the Harrisburg metropolitan area. I wasn't aware that a good telescope can cut through the glare and smog. How does it do that?
City viewing of the Moon, Jupiter, and Saturn is quite good. Viewing of deep sky objects is affected by light pollution, but the size of the telescope can compensate partially. There is a(n) (untrue) myth that large telescopes shouldn't be used in the city because they gather more of the light pollution than smaller scopes. This myth is addressed on page 15 of The Urban Astronomer`s Guide by Rod Mollise,
http://books.google.ca/books?id=Z0m...&resnum=3&ved=0CBAQ6AEwAg#v=onepage&q&f=false.
I'm 24 miles from dead-center in Philadelphia and the population density is pretty high everywhere in SE PA - you can see what I have been able to do from my website. How far are you from Harrisburg?
I don't do much visual observing, so I can't say much about how galaxies look with your eyes through a scope, but the basic principle for photography is this: Light pollution brightens the entire image, including the object you are imaging. So using Photoshop, you can simply subtract this extra brightness from the image. It isn't perfect, but you can do a surprising amount of good photography from near a city.
You may surprised to learn that temperature inversions over cities can provide very steady viewing for planetary targets. Some of my steadiest views of Jupiter came from my suburban back yard.
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
