fluxions
- 50
A star of mass M and radius R is moving with velocity v through cloud of particles of density \rho. If all the particles that collide with the star are trapped by it, show that the mass of the star will increase at a rate
\frac{dM}{dt} = \pi \rho v \left(R^2 + \frac{2GMR}{v^2}\right).
Assuming the motion of the star is rectilinear, it's evident that in a time \Delta t the star will collide with all the particles in a cylinder of length v \delta t, which has mass \pi R^2 \pho v \Delta t. This gives the first term in the desired equation after division by v \Delta t.
As for the second term... I'm stuck. Here's what I've tried: Consider the particles in a 'slab' (of thickness dr) of the aforementioned cylinder a distance r away from the center of the star at the beginning of the time interval \Delta t. This slab will experience an acceleration GM/r^2. Hence, assuming it started from rest, it will travel a distance \frac{GM (\Delta t)^2}{r^2} in the time interval \Delta t. Et cetera. I don't know how to proceed from this point.
