Static Electricity: Can You Still Get a Shock Off the Ground?
Static electricity can still cause a shock between two people even if they are off the ground, as long as there is a charge difference between them. When person A, carrying an electrostatic charge, touches person B, a transfer of charge occurs, similar to discharging a capacitor. Being off the ground means neither person is earthed, but this does not prevent the transfer of charge. The peak current may be lower than if they were grounded, but a shock can still occur. Therefore, grounding is not a requirement for static discharge to happen.
Iamnotarobot120
A (possibly stupid) static electricity question:
Person A is carrying an electrostatic charge. They touch person B, both get a shock.
If both persons were off the ground(eg hanging from ropes) ...would they still get a shock?
Why wouldn't they?
Because neither are earthed?
The difference will be that A won't get completely discharged but its charge will be distributed over the two persons. Like discharging a capacitor on another one.
The peak current may be less than in the other case.
Likes Delta2
they don't have to be
as long as a charge difference exists between them, there will be a transfer of charge
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
