Static Friction- Train stops, boxes move?
The discussion revolves around calculating the stopping distance of a train with crates on a flatcar, given a coefficient of static friction of 0.25 and an initial speed of 48 km/h. The user attempts to determine the maximum deceleration and stopping distance but encounters confusion in their calculations. A key point raised is the need to square the initial speed when applying the kinematic equation. The correct approach involves using the maximum static friction to find the deceleration, which is crucial for preventing the crates from sliding. Accurate application of the formulas will yield the correct stopping distance.
battlebball
The floor of a railroad flatcar is loaded with loose crates having a coefficient of static friction of 0.25 with the floor. If the train is initially moving at a speed of 48 km/h, in how short a distance can the train be stopped at constant acceleration without causing the crates to slide over the floor?
F = ma
f(s)max= u(s)N
final v^2-init. v^2 = 2a*s(distance)
Newton's second law?
I've been cracking my skull on this one... I search and found this https://www.physicsforums.com/showthread.php?t=186380 however, I couldn't figure it out.
Is the maximum deceleration -.25g? But when I plug that into: 0-13.33=2*a*s => -13.33/(-2*.25*9.8) = 2.72m and obviously something is wrong... Thanks in advance.
battlebball said:
F = ma
f(s)max= u(s)N
You forgot to square the speed v=13.33 m/s.
ehild
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
