How Do You Apply the First Theorem of Pappus-Guldinus to Calculate Surface Area?
  • Thread starter Thread starter O011235813
    Statics
O011235813
hey, I'm having issues with a problem, and my book doesn't seem to show me how to do it.
so,
i have a curve x = ky^2 and I'm to rotate it about the x-axis. I need to find the surface area generated.
How do i use the first theorem to do this? Thanks for the help
sorry i don't have a pic of the problem. but if you want to see here's a link to my book:
http://books.google.com/books?id=l-...&hl=en&sa=X&oi=book_result&resnum=1&ct=result
problem number 5.60
thanks once again
so,
problem number 5.60
thanks once again
Welcome to Physics Forums.
Before we can help you, you need to show some effort in solving the problem yourself, either providing an attempted solution or at least detailing your thought.
Stating the theorem of Pappus and then seeing what you can do from there be a good start.
hey,
thanks for the welcome. I figured it out. It was just a bunch of math that I haven't done in the longest time. i had to figure out what k was which is where i messed up at the beginning. I used:
x = ky^2 and i just put b and a so...
a = kb^2 and found k to be b...which was wrong.
it was a system of equations cause there was a length to the object:
a + 15 = k(12.5)^2
a = k(7.5)^2
solving that i got k to be .15
so x = .15y^2
then applying the theorem:
A = 2(pi)(yL) = integral(2(pi)(yL), L, 0, b)
and solve that to get the answer.
Thanks for willing to help.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
