Statics with an engine regulator
The discussion focuses on a physics homework problem involving the relationship between angular speed and angle in a system with a counterweight performing uniform circular motion. The key equation derived is ω² cos(θ) = (1 + 2m'/m) g/L, which relates angular speed (ω) and angle (θ) under specific conditions. Participants suggest using separate vertical equations for the masses involved to solve the problem correctly. The initial attempt at a solution is acknowledged, but further clarification and steps are encouraged for accuracy. The conversation emphasizes the importance of systematic analysis in solving statics problems.
hurrfdurrf
[PLAIN]http://img15.imageshack.us/img15/7379/unledtzc.png
(The rods are of length L, there is no friction, massless rods, yadee yadee yada)
At a certain angular speed \omega, the counterweight performs uniform circular motion. Show that \omega and \theta are related as follows:
\omega^2 \cos{\theta} = (1 + \frac{2m'}{m}) \frac{g}{L}
T_1 = L m \omega^2
\cos{\theta} (T_1 - T_2) = g (m + m')
(Working backwards) Combined above to get
T_2 \cos{\theta} = m' g
which makes a lot of sense, but I'm not sure if the procedure was right
welcome to pf!
hi hurrfdurrf! welcome to pf! :wink:
you need vertical equations for mass m and for mass m' (separately) …
what do you get? :smile:
