Stating logarithm in variables
The discussion centers on expressing ##\log \sqrt{1000}## in terms of variables a and b, where a = ##\log 3## and b = ##\log 5##. Participants initially struggle to relate the logarithm to these variables without resorting to unconventional methods. It is clarified that the question should indeed focus on expressing the logarithm in terms of a and b, rather than other variables. The conversation reveals confusion about the problem's wording, with some suggesting it may contain errors, which the teacher later confirms. Ultimately, the correct expression is indicated to be ##\frac{3}{2} (a + b)##, although the question's validity remains in question.
songoku
Given that ##a=\log 3## and ##b=\log 5##, state ##\log \sqrt{1000}## in terms of u and/or v
Logarithm properties
Have tried to do that but getting no result.
I know ##\log \sqrt{1000} = \frac {3}{2}## . I just want to know whether it is possible to state ##\log \sqrt{1000}## in terms of u and/or v without using "weird stuff", like ##\log \sqrt{1000} = \frac{3}{2} + u - u ## (this is what I did...)
Thanks
songoku said:
Homework Statement:: Given that ##a=\log 3## and ##b=\log 5##, state ##\log \sqrt{1000}## in terms of u and/or v
Relevant Equations:: Logarithm properties
Thanks
Should this have been "state ##\log \sqrt{1000}## in terms of a and/or b"? If not, I have no idea what this problem is asking.
Likes songoku
Mark44 said:
Should this have been "state log⁡1000 in terms of a and/or b"? If not, I have no idea what this problem is asking.
Ah I am sorry, my bad. I got mixed up with another question I did.
Yes, the question should be: "state ##\log⁡ \sqrt{1000}## in terms of a and/or b"
What I did was trying something and ended up with: ##\frac{3}{2} +a - a##
I don't think that's what they were looking for.
10 = 2 * 5, so ##\log 10 = \log(2 * 5) = \log 2 + \log 5##
Can you work with that?
Likes songoku
I can try
##\log \sqrt{1000} = \frac{3}{2} \log 10 = \frac{3}{2} (\log 5 + \log 2) = \frac{3}{2} = (b + \log 2)##
How to relate ##\log 2## to ##a## or ##b## ?
Thanks
songoku said:
I can try
That last part should be ##\frac{3}{2} (b + \log 2)##, not ##\frac{3}{2} = (b + \log 2)##
2 = 10/5, so ##\log 2 = \log 10 - \log 5##
Likes songoku
Yes, sorry that's typo
So:
##\log \sqrt{1000} = \frac{3}{2} \log 10 = \frac{3}{2} (\log 5 + \log 2) = \frac{3}{2} (b + \log 2)##
##=\frac{3}{2} (b + \log 10 - \log 5)##
##=\frac{3}{2} (b + 1 - b)##
##=\frac{3}{2} \rightarrow ## no ##a## or ##b## ?
Thanks
Just checking - are you sure log here is log base 10, and not natural log?
I also feel like they must have meant to say a=log(2).
The whole question as you've stated it is a bit weird.
Likes songoku and FactChecker
Yes the base of the logarithm is 10
a is log (3) because it is also used in other part of the question
Maybe the question is wrong
Thank you very much for all the help Mark44 and Office_Shredder
That would make a bit more sense, if there were eight questions all using the same a and b, and one of them happened to not need them to expressed as a fraction.
Likes songoku
Unfortunately, 3/2 is stated as wrong answer by the system 😅
Hmm. Have you tried 1.5?
I really don't know what they are looking for, sorry.
Likes songoku
I'm not sure if this is the goal but ...
I removed the log by raising 10 to the powers ##a## and ##b##, then multiplied the result$$10^a10^b=15=15\frac{1000}{1000}\Leftrightarrow\frac{10^3}{15}10^{a+b}=1000\Leftrightarrow\sqrt{\frac{10^{a+b+3}}{15}}=\sqrt{1000}$$now we just use ##\log##, i guess.
Likes songoku
It sounds like there is more to the problem statement than the OP indicates. The other parts might clarify it.
Likes songoku
songoku said:
So:
Perhaps ##\frac 32 = \frac {15}{10} = \frac{3\cdot 5}{10}## can help.
Likes songoku
@songoku ,
Combine the idea by @archaic in Post #13: ##\quad a=\log_{10}(3) \Leftrightarrow 10^a=3## etc.
with the suggestion by @vela in Post #15.
Likes songoku and archaic
The teacher admitted that the question is wrong.
Sorry everyone for all the trouble
However, the answer you arrived at can be expressed in terms of a and b.
##\dfrac 3 2 = 10^{(a+b-1)} ##
Added in Edit:
The above was corrected per post #19.
Likes Chestermiller and songoku
##\dfrac 2 3 = 10^{(a+b-1)} ##
Yes I tried that but the correct answer came out as: ##\frac{3}{2} (a+b)## , that's why the teacher canceled the question
And I think there is typo, ##\frac{2}{3}## should be ##\frac{3}{2}##
Thank you SammyS
Likes SammyS
I get lost in long threads like this, not even sure if you have solved, but sole factors of 1000 are powers of 5 and 2. You are essentially given 5 and 2 to play with, while the problem involves 3 and it looks like you have difficulty in discovering a relation between these numbers. :smile:
