Automotive Steering Mechanism: Turning Front Wheels of 4 Wheeler
The discussion focuses on modifying a conventional steering mechanism to allow the front wheels of a four-wheeler to turn at different angles, specifically 90 degrees for one wheel and 54 degrees for the other. The Ackermann effect is mentioned as a relevant concept for understanding standard steering systems. Adjusting the connection of the steering knuckle to the wheel's center may enable this functionality, although precision is uncertain. The user is working on a mechanical engineering project aimed at minimizing the turning radius. This innovative approach could enhance maneuverability in tight spaces.
amit577
can anybody tell me how to turn the front two wheels of an 4 wheeler in different angles by making small changes in conventional steering mechanism.
google ackermann effect on standard steering system
hey i am thinking of turning of the right and left wheels in different direction.
eg:i want to turn front right wheel in 90degree and the left wheel in 54degree.
It might help to explain why you'd want to do something like that or what you're trying to accomplish.
The steering knuckle is usually connected to one side of the centre of the wheel to make the wheel turn. Adjusting it such that it connects to the other side of the centre could help you achieve this, although I'm not sure how accurately.
Watching this video might give you a better idea of what I'm talking about:
im in last yr mech engg and i am doing my project on minimum turning radius in which i want to turn one wheel at 90 degree and the other at an angle around 55 degree
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
