I Stefan-Boltzmann Law: IvdvcosΘdw Explained
The discussion centers on the Stefan-Boltzmann Law and the integration of radiative flux IvdvcosΘdw for a spherical black body. It clarifies that the integration is performed from 0 to pi/2 because the black body can only emit radiation in one hemisphere, where the flux is non-zero. The concept of solid angle and frequency is also mentioned, emphasizing the importance of these variables in calculating radiative flux. The reasoning behind limiting the integration to the upper hemisphere is rooted in the physical properties of black body radiation. Understanding this integration is crucial for accurately applying the Stefan-Boltzmann Law in thermal radiation contexts.
Apashanka das
I am having a doubt of why is the radiative flux IvdvcosΘdw in equilibrium integrated for a spherical black body only from 0 to pi/2 not pi(e.g. For the entire surface for which it is zero),
v=frequency
dw= solid angle
It is a surface, it can only emit radiation in one hemisphere.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
