Stellar aberration measurement
In summary, Joseph is looking to measure stellar aberration and is interested in advice from others. He plans to use Alpha Centauri as a target, and is measuring it 6 months apart to get the greatest difference in parallax measurement. He plans to use a stationary telescope with a DSLR camera.
jk1956
Hi everyone,
I am interested in measuring stellar aberration as a challenge to myself; I am more of a physicist than an astronomer. I have a fair knowledge of telescopes and imaging. I would appreciate if somebody can give me instructions or point to some references on: which star to select, what time at night to conduct measurement, how often to measure etc. My goal is to obtain better than 1" accuracy. I intend to use a stationary telescope with a DSLR camera, with the recorded images analysed to determine position shift.
I am in the southern hemisphere, Sydney, Australia. I could not find a description of stellar aberration measurement procedure in my searches, except Bradley' original paper. Thanks for your interest.
Regards,
Joseph
Astronomy news on Phys.org
Will be hard to see anything if you don't reach that. Alpha Centauri has the largest parallax at 750 milliarcseconds (not counting the slightly nearer but much dimmer Proxima Centauri).
Nearby bright stars, with more distant bright stars nearby as reference (ideally in the direction of parallax shifts), should be the best targets.
More measurements give better accurary, so does a longer timespan (probably go for a year, otherwise it is hard to separate the small parallax from the proper motion).
I don't know the best time of the night. Atmospheric turbulences should be as weak as possible.
Hi Joseph
welcome to the Physics Forums
I am also in Sydney ( inner west)
cool winter nights are the best for lowest atmospheric turbulence ( summer not so good).
Also use Alpha Centauri as mfb suggested and when it is highest in the sky so you are looking through the least amount of atmosphere.
measuring 6 months apart will give the greatest difference in parallax measurement and you would want to do multiple measurements at each of those 6 monthly intervals to get a good avg measurement at those times
cheers
Dave
Hi mfb and Dave,
Thank you very much for your replies. Based on your suggestions, I may try Alpha Centauri, when it is highest in the sky.
May I clarify that I am planning to measure stellar aberration, which I believe, is around +/- twenty arc second over the period of an year. My understanding is that the much smaller parallax is superimposed on stellar aberration, but with a 90 deg phase shift. Also, parallax will depend on the distance to the star being measured, whereas stellar aberration, arises solely due to the motion of the observer (earth in our case). Unfortunately, one cannot depend on any 'reference stars', as all stars will exhibit stellar aberration to the same degree.
Any suggestions on stable telescope mounting techniques for the long period of measurement needed is appreciated.
Dave, I live in the suburb of Pennant Hills and work in the inner west; is there any place or gathering of professional/ amateur astronomers in Sydney where I can ask for some tips?
Regards,
Joseph
Oh, somehow I read parallax. Aberration is a different challenge, the effect is larger but you cannot use other stars as reference, right.
Likes davenn
eeekkk ... We both did, mfb :rolleyes:
Apologies Joseph
I might have to read up on that.
I thought stellar aberration was to do with oscillations due to orbiting planets ... apparently that must have another name
http://www.colorado.edu/physics/phys2170/phys2170_fa06/downloads/stellar_aberration.pdf
OK I have some learning to do LOL
just up the hill from me in West Ryde :smile:
The ASNSW ( Astronomical Soc of NSW) meet at Macquarie Uni
I am a member but haven't been to a meeting for yonks
http://www.asnsw.com/cheers
Dave
Hi Dave and mfb,
No worries.
Dave, thanks; I will check out ASNSW.
Regards,
Joseph
1. What is stellar aberration measurement?
Stellar aberration measurement is a technique used by astronomers to determine the apparent shift in the position of a star due to the Earth's motion around the Sun.
2. How is stellar aberration measured?
Stellar aberration is measured by using a telescope to observe the position of a star at different times of the year. By comparing the star's position relative to other stars, the apparent shift caused by the Earth's motion can be calculated.
3. Why is stellar aberration important in astronomy?
Stellar aberration is important in astronomy because it allows us to accurately determine the speed of light and the Earth's orbit around the Sun. It also helps us to understand the effects of the Earth's motion on the apparent position of stars.
4. How does the speed of light affect stellar aberration?
The speed of light is a crucial factor in stellar aberration measurement. The faster the speed of light, the larger the apparent shift in a star's position will be. This is because the Earth's motion causes the light from the star to appear to come from a different direction.
5. Can stellar aberration be used to study other celestial bodies?
Yes, stellar aberration can also be used to study other celestial bodies such as planets and asteroids. By measuring the apparent shift in their positions, we can learn more about their orbits and motion in our solar system.
  • Astronomy and Astrophysics
