Calculating Acceleration of Stellar Engines: A Comparison to Wikipedia Example
In summary, the conversation discusses the physics of stellar engines and specifically the calculation for the acceleration due to light pressure of a "Shkadov thruster". The Wikipedia example is mentioned and the conversation delves into the derivation of the numbers. It is noted that the thruster is a half-shell and needs to be made of super-materials to be strong enough at that scale. Eventually, it is concluded that the shell needs to be shaped like a paraboloid with the sun at the focus to produce the desired thrust.
mistergrinch
44
Has anyone here looked at the physics of stellar engines? See http://en.wikipedia.org/wiki/Stellar_engine for an overview. In particular, I have done a simple calculation for the acceleration due to light pressure of a "Shkadov thruster", which is a reflective shell on one side of a star that stays in place due to the equilibrium of gravity and light pressure. My calculation for the acceleration this would produce on a star seems to be off by a factor of 4 from the Wikipedia example, which states:
For a star such as the Sun, with luminosity 3.85 × 10^26 W and mass 1.99 × 10^30 kg, the total thrust produced by reflecting half of the solar output would be 1.28 × 10^18 N. After a period of one million years this would yield an imparted speed of 20 m/s, with a displacement from the original position of 0.03 light-years. After one billion years, the speed would be 20 km/s and the displacement 34,000 light-years
Is anyone able to derive these numbers? Thanks!
Astronomy news on Phys.org
I got the same as the Wikipedia quote. How did you derive what you got?
Hmm OK I guess I don't understand the physics then. I'm thinking of photons being emitted in all directions, but half of them are hitting the reflective shell, which transfers momentum to the shell which then tugs on the star by gravity. I assumed an absorbing shell, because it seems to me that a reflective shell would just bounce the photons back to the star, counteracting the gravity tug and the star would go nowhere.
I used the radiation pressure P = Intensity/c = L /(4pi*r^2*c), where L is the luminosity of the sun.
If I calculate the radiation force on the shell in the x direction using differential ring elements I get the equation
dF = P*dA = L/(4*pi*r^2*c) * 2*pi*r^2 * sinB*dB =>
dF_x = L/2c * sinB * cosB dB
where B is the angle from the axis of the ring to the edge
Integrating this from A=0 to pi/2 gives F_x = L/4c = 3.25 * 10^17, which is 1/4 the value given in Wikipedia. Where am I going wrong here?
Hi mistergrinch
First, the Skhadov thruster is a half-shell. Half the Sun is exposed, thus the emission from that direction produces net thrust too, because light directed at the shell is bounced rearwards. The shell is shaped like a concentrating mirror, but working in reverse so the light emitted at the the focus, by the star, is reflected away from the mirror (and star) to produce thrust. The Wikipedia diagram doesn't seem quite right. The mirror needs to cover more solid angle in the direction of motion to produce the most thrust. My thrust figure is an idealization, but should be pretty close. The Thruster would need to be made of super-materials to be strong enough at that scale.
Oh I get it now, you can shape the shell any way you want if you choose the shell density so that radiation pressure cancels gravity at any distance. So you shape the shell like a paraboloid with the sun at the focus. If you crunch the numbers for a reflective shell you get F = L/c. Thanks!
Right on.
What is a Stellar Engine?
A Stellar Engine is a hypothetical megastructure that would harness the energy of a star to power advanced civilizations. It would involve constructing a large structure around a star, such as a Dyson sphere, to capture and utilize its energy.
How is a Stellar Engine calculated?
The calculation for a Stellar Engine involves complex equations and simulations that take into account the mass, temperature, and energy output of the star, as well as the materials and design of the megastructure. Supercomputers are often used to perform these calculations.
What is the purpose of calculating a Stellar Engine?
The purpose of calculating a Stellar Engine is to determine the feasibility and potential benefits of constructing such a megastructure. It can also help scientists understand the energy needs and capabilities of advanced civilizations.
What are the challenges in calculating a Stellar Engine?
One of the main challenges in calculating a Stellar Engine is the lack of precise data on stars and their behavior. This can lead to uncertainties and limitations in the accuracy of the calculations. Additionally, the complexity of the equations and the vast scale of the project make it a difficult task.
Are there any real-life examples of a Stellar Engine?
Currently, there are no known examples of a functioning Stellar Engine in our universe. However, the concept has been explored in science fiction and is being studied by scientists as a potential future technology for advanced civilizations.
  • Astronomy and Astrophysics
  • Science Fiction and Fantasy Media
