Andre
- 4,310
- 73
The number of stomata on leafs (breathing pores) of certain plant species appears to be sensitive to the CO2 level in the atmosphere. If it is higher, it appears that these plants does not bother to make many stomata, whereas CO2 is scarce, it simply makes more stomata to extract the CO2 from the atmosphere.
So if we have fossil leafs of these species, with some accurate dating, it might be possible to reconstruct CO2 levels from the past and perhaps much better than ice cores, since there are several problems associated with the accuracy of ice cores.
A first thread about that concept is here. The University of Utrecht in the Netherlands appears to be the mark leader in this specialty and http://www.pnas.org/content/early/2008/10/03/0807624105.full.pdf:
The study refers to earlier work in Washington on Tsuga needles, which is reported in this PhD thesis. Note that the graphs of fig 1c and fig 5.4 on page 57 (Pdf:61) of the thesis appear to correlate reasonably both with maximums around 1000AD and 1350AD and a minimum around 1200AD giving it a certain robustness.
Furthermore, they make a temperature reconstruction based on the alleged dependence of temperature on CO2 (Fig 2) with a 0,1-0,2C order of magnitude temperature variation. See a concluding remark:
I find it curious however that they did not test their work to other temperature reconstructions in that period, If we do that, for instance with the new & improved hockey stick discussed here, with an minimum at around 1350AD, instead of a maximum, one would tend to think that it would support the CO2 cooling hypothesis rather than the CO2 warming hypothesis.
Thomas B. van Hoof, Friederike Wagner-Cremer, Wolfram M. Ku¨
rschner†, and Henk Visscher 2008, A role for atmospheric CO2 in preindustrial climate forcing
PNAS September 30, 2008, 105 (39)
Abstract
Complementary to measurements in Antarctic ice cores, stomatal frequency analysis of leaves of land plants preserved in peat and lake deposits can provide a proxy record of preindustrial atmospheric CO2 concentration. CO2 trends based on leaf remains of /Quercus robur/ (English oak) from the Netherlands support the presence of significant CO2 variability during the first half of the last millennium. The amplitude of the reconstructed multidecadal fluctuations, up to 34 parts per million by volume, considerably exceeds maximum shifts measured in Antarctic ice. Inferred changes in CO2 radiative forcing are of a magnitude similar to variations ascribed to other mechanisms, particularly solar irradiance and volcanic activity, and may therefore call into question the concept of the Intergovernmental Panel on Climate Change, which assumes an insignificant role of CO2 as a preindustrial climate-forcing factor. The stomata-based CO2 trends correlate with coeval sea-surface temperature trends in the North Atlantic Ocean, suggesting the possibility of an oceanic source/sink mechanism for the recorded CO2 changes.
Reconstructed multidecadal changes are not as prominent as man-made CO2 increases since the onset of industrialization. Yet it seems obvious that a dynamic CO2 regime with fluctuations of up to 34 ppmv implies that CO2 can no longer be discarded as a forcing factor of preindustrial air-temperature changes.
