Strength of magnetic field at a point
The discussion centers on calculating the strength of the magnetic field at point P due to semicircular wires. The user initially applies the formula B = u*I/(2*pi*d) for straight wires, resulting in an incorrect value of 5×10^-5 T instead of the expected 7.9×10^-5 T. It is highlighted that the formula used is not suitable for semicircular wires, which require a different approach. Participants suggest reviewing textbook resources for the appropriate formula for semicircular configurations. The conversation emphasizes the importance of using the correct equations for specific geometries in magnetic field calculations.
erinec
http://img291.imageshack.us/img291/9572/picture2ehv.png
What is the strength of the magnetic field at point P?
The answer is 7.9×10^−5 T.
However, I used the equation B = u*I/(2*pi*d) and keep getting 5*10^-5 T.
B = u*I / (2*pi*d)
Nearer wire:
B = uI/(2*pi*d) = (1.257*10^-6)(5.0)/(2*pi*0.02) = 0.00005 T
Further wire:
B = uI/(2*pi*d) = (1.257*10^-6)(5.0)/(2*pi*0.01) = 0.0001 T
Total B:
B = 0.0001T - 0.00005T = 0.00005 T
What am I doing wrong?
Hi erinec,
B = u*I / (2*pi*d)
This formula gives the magnitude of the B-field of a long straight wire (at a distance d away from the wire).
But in this problem you don't have straight wires creating the magnetic field at P; the wires are semicircles. Look through your textbook again and see if you can find a formula that better fits this situation.
