Strong Induction: Show 1\leq x_{n} \leq2 for all n \epsilon N
  • Thread starter Punkyc7
  • Tags
    Induction
In summary: So, we need to show that1 \le x_{n+2} \le 2implies thatx_{n+1} = \frac{1}{2} (x_{n} + x_{n-1})which is what we wanted to show in the first place.
Punkyc7
420
Let the number x[itex]_{n}[/itex] be defined as follows x[itex]_{1}[/itex] = 1 and x[itex]_{2}[/itex] =2 and x[itex]_{n+2}[/itex]=[itex]\frac{1}{2}[/itex](x[itex]_{n+1}[/itex] +[itex]_{n}[/itex]) for all n [itex]\epsilon[/itex] N. Use the principle of strong induction to show that 1[itex]\leq[/itex]x[itex]_{n}[/itex] [itex]\leq[/itex]2 for all n [itex]\epsilon[/itex] N
I have never done strong induction before so is this right?
Pf/
so P(1) is obvious
Assume true for P(1)...P(n). WTS true for P(n+1).
So P(n+1)= x[itex]_{n+3}[/itex]=[itex]\frac{1}{2}[/itex](x[itex]_{n+2}[/itex] +x[itex]_{n+1}[/itex]). Since
x[itex]_{n+3}[/itex]=[itex]\frac{1}{2}[/itex](x[itex]_{n+2}[/itex] +x[itex]_{n+1}[/itex])= [itex]\frac{1}{2}[/itex](x[itex]_{n+1}[/itex] +x[itex]_{n}[/itex]). Since its true for [itex]\frac{1}{2}[/itex](x[itex]_{n+1}[/itex] +x[itex]_{n}[/itex]) by our induction hypothesis its true for for n+1.
The text formatting at the beginning is all sorts of messed up, but I think I get the problem.
There's still a problem with your inductive step. You have
[tex]x_{n+3} = \frac{1}{2} (x_{n+2} + x_{n+1})[/tex]
which is correct, but your next equality doesn't follow. Based on your inductive hypothesis, however, what do you know about [itex]x_{n+2}[/itex] and [itex]x_{n+1}[/itex]?
Sorry about the confusion I got lost with all the formatting
they are at least 1 and at most 2.
So would you say by our hypothesis x[itex]_{n+3}[/itex] is either [itex]\leq[/itex]2 or [itex]\geq[/itex] 1 because x[itex]_{n+1}[/itex] and [itex]_{n+2}[/itex] are both either [itex]\leq[/itex]2 or [itex]\geq[/itex] 1
and at most (2+2)/2 =2 and at least 2/2=1
You seem to be uncertain of precisely what the proposition (or property) is here.
No I think he's got it, but he's having some trouble with formatting properly with tex. He's setting [itex]P(n) = [1 \le x_{n+2} \le 2][/itex], which is a little awkward for me but it works.
I like to do inequality things pretty formally, so here's how I would do it:
Assume it holds for [itex]x_{k}[/itex] for all [itex]k \in {1,2,...,n}[/itex].
By definition,
[tex]x_{n+1} = \frac{1}{2} (x_{n} + x_{n-1})[/tex]
and by our hypothesis
[itex]1 \le x_{n} \le 2[/itex] and [itex]1 \le x_{n-1} \le 2[/itex].
I don't want to totally give it away, so write your own continuation first before reading the rest.
[tex]2 \le x_n + x_{n-1} \le 4[/tex]
[tex]1 \le \frac{1}{2} (x_n + x_{n-1}) \le 2[/tex]
[tex]1 \le x_{n+1} \le 2[/tex]
I understand what you did for the most part but how did you know to do x[itex]_{n+1}[/itex] instead of what was x[itex]_{n+2}[/itex] that was given?
When you're making a statement involving n in your induction, it is not explicitly the same n as from earlier in the recursive definition. This statement, which starts the introduction:
Assume, for all k in {1, 2, ... ,n}, for some n, that we have that [itex]1 \le x_{k} \le 2[/itex].
says that it holds for some arbitrary n. This "resets" the use of n from earlier in the recursive definition. If you are more comfortable, you could swtich one of them to "m" instead.
so x[itex]_{n+2}[/itex] is there just to confuse us
No, it shouldn't confuse you... I think you should think about what both statements mean (not just what the algebraic notation looks like).
[tex]x_{n+2} = \frac {1}{2}(x_{n+1} + x_{n}) \qquad \forall n \in {1, 2, ...}[/tex]
This means that, after the first two, each value of x is equal to half the sum of two before it. That's it. n just serves as a placeholder so that we can write that statement algebraically.
When working with any inductive statement, we want something to be true "for some arbitrary n", and then we want to show that the fact that it is true for this n necessarily implies that it is true for n+1.
In the context of our proof, this means that we need to show that the knowledge that all x in the sequence before some arbitrary place are greater than / equal to 1 and less than / equal to 2 necessarily implies that the next x in the sequence is also greater than / equal to 1 and less than / equal to 2. n just serves as a placeholder so that we can reference this place in the sequence again later.
1. What is strong induction?
Strong induction is a proof technique used in mathematics to prove that a statement is true for all natural numbers. It involves using the fact that a statement is true for all smaller values, as well as a base case, to prove that it is true for all natural numbers.
2. Why is strong induction necessary?
Strong induction is necessary because some statements cannot be proven using regular induction. Regular induction only uses the fact that a statement is true for the previous value to prove it is true for the next value. However, with strong induction, we can use the fact that a statement is true for all previous values to prove it is true for the next value.
3. How do you use strong induction to prove a statement?
To prove a statement using strong induction, you must first establish a base case. This is usually the smallest value for which the statement is true. Then, you assume that the statement is true for all values up to a certain value, and use this assumption to prove that the statement is also true for the next value. This process is repeated until the statement is proven to be true for all natural numbers.
4. Can strong induction be used for all mathematical statements?
No, strong induction can only be used for statements that involve natural numbers. It cannot be used for statements involving real numbers or other types of mathematical objects.
5. How is strong induction different from regular induction?
The main difference between strong induction and regular induction is the assumption used to prove a statement. In regular induction, the assumption is only based on the previous value, while in strong induction, the assumption is based on all previous values. This allows strong induction to prove statements that regular induction cannot.
