Strong Steel wire but an elastic spring? Why?
Steel wire exhibits strong tensile strength, allowing it to function as an elastic spring when coiled. The coiling process enables the wire to withstand twisting motions and opposing torques, similar to how a straight rod would resist such forces. Stress and strain can be analyzed in both the straight and coiled forms under torque applications. When loaded axially, the coiled spring's resistance to shear and bending can be neglected, focusing solely on the axial load. Understanding these principles can clarify the mechanical behavior of steel wire in spring applications.
tlfx1996
The steel wire can withstand strong tensile stress, but when the steel wire is being coiled into a spring it can be an elastic spring. Why is this? Can this be proven mathematically?
How much resistance will that strong steel wire provide against a twisting motion, opposing torques applied to opposite ends of the wire, which is most of the relative deformation in the case of a spring?
I'm sorry, can you explain your answer straight away. Ii'm not sure of the answer. thx
A straight rod will have some resistance to being twisted or having a torque applied to it. There will be a stress and strain asscociated with the amount of twist.
Now coil up the rod into the shape of a coiled spring. If a force is put on the spring, the rod, or rather a cross section through a part of the coiled rod, even though coiled up, can be analyzed for the stress and strain in the same manner as the straight rod experiences a torque.
For a coiled spring loaded axially,
http://www.codecogs.com/library/engineering/materials/springs.php
http://nptel.iitm.ac.in/courses/Web...ials/lects & picts/image/lect20/lecture20.htm
When they say shear and bending can be neglected, they mean a pure axial load, so no sideways force or a moment is to be applied to the spring.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
