Glucose Heating w/ HI: Why Get N-Hexane? | Reaction Explanation
  • Thread starter Thread starter erisedk
    Glucose Structure
Prolonged heating of glucose with hydroiodic acid (HI) leads to the formation of n-hexane through a reduction reaction. In this process, HI acts as a reducing agent, resulting in the oxidation of HI to iodate. This reaction is notable for its application in the synthesis of methamphetamine, as depicted in popular media. The mechanism involved is a type of reduction, which may not be commonly highlighted in introductory organic chemistry courses, where the focus is often on alcohols yielding halogen-substituted products. Understanding this reaction expands the knowledge of carbohydrate chemistry and its potential transformations.
erisedk
Why does glucose on prolonged heating with HI give n-hexane?
What mechanism/reaction type is this? All I knew till now was that alcohols would give halogen substituted products with hydrogen halides.
Chemistry news on Phys.org
It's a reduction with hydroiodic acid being oxidized to iodate. Btw the same reaction is used in the synthesis of methamphetamine in beeaking bad.
Is it a common mechanism in introductory organic chemistry?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
