Student Questions on Forces for Forensic Anthropology Research | MSc. Project
The discussion revolves around a research project in Forensic Anthropology focused on studying the impact of bladed weapons on bones. Key questions include estimating the optimal swing angle for consistent force application, calculating the cutting edge surface area of axes, and whether pendulum formulas can be applied. Suggestions include using a micrometer for measuring blade thickness and applying principles from the Charpy Impact Test to determine swing dynamics. The participant expresses a need for clarification on how force relates to swing angle and acknowledges a limited understanding of potential and kinetic energy in this context. Overall, the conversation emphasizes the importance of precise measurements and understanding physical principles in forensic research.
Schwarzenberger
Hi everyone!
I have few questions which I think might actually be simple, but I would like some confirmation if possible.
Here's the situation:
I am doing a research project for my MSc. in Forensic Anthropology. The goal of my project is to study the marks left on bones by bladed weapons (in this case, axes) depending on the force applied. I have a device which allows me to fix an axe on it an to "swing" it to hit a bone. The arm on which the axe is fixed measures 51.9 cm, and weight 5143g. The weight of the axes varies between 650g and 1Kg.
My questions were:
- Given that I study the force applied, is it possible to estimate the angle at which I should swing the axe to obtain the same force every time (with every axes)?
- How can I calculate the surface area of the cutting edge of the blade?
- Should I use the formulae to calculate the force of a pendulum?
Thanks a lot!
I'm definitely not an expert on the subject, but this sound interesting to me so this is how I would do it if I had to; maybe others can point out errors in my approach.
I think a Palmer screw is the right instrument to measure the thickness ##h## of your axes' edge: https://en.wikipedia.org/wiki/Micrometer.
To estimate the length ##l## I would put the tip of the axe's edge on a plywood board, apply some pressure, and then roll it all over; the cut left on the plywood should be, to an acceptable degree of accuracy, the stretching of a circular arc over a plane, and then you can measure it with any simple ruler.
At this point your surface will be ##S = hl##
With regard to the "swing angle", I assume your device is somewhat like a torsion pendulum, where you put your axe in an initially stable equilibrium position and then you can pull it back, describing an angle ##\alpha##, and in the moment you let the axe go torque swings your axe back toward the equilibrium position. If my interpretation is right then yes, you can estimate the angle at which you should swing your axe to obtain a certain force just by setting up the differential equation for an oscillator.
Google ' Charpy Impact Test ' and ' Charpy Impact Test Formula '
Thanks a lot for your replies!
It actually make a lot of sens to me, which I hope is a good thing.
Concerning the angle, the device is like a rectangular frame (small sides up and down and long sides on the right and left) with a swinging arm fixed on the upper side. I though about tapping an axe on it and then pull the arm back to a certain angle, and let it fall forward to hit the bone. I have a laser I can use to measure the speed of the axe.
I will try to figure out how to determine the angle, because I guess the weight of the axe (added to the weight of the arm) will have a major influence on it.
This may be a silly question, but does a force changes proportionally to the angle? For example, if I use a 600g axe and an angle of 20°, will the force be twice as big if I use an angle of 40°?
Thanks again!
(1) The actual cutting action will generally involve shearing , elastic deformation , plastic deformation , stress concentration and crack propagation .
(2) Do you understand what potential and kinetic energy are and how to use them to solve dynamics problems ?
I have to admit that my knowledge in that area is very limited. I would need to do some reading to understand that.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
