How Do You Solve for t in a Cubic Parametric Equation?
  • Thread starter jjj888
  • Tags
    Parametric
In summary, the conversation is about solving for t in the equation x=at^3+bt^2+ct+d and the attempt at using parametric equations to simplify the equation. Both parties discuss possible methods and consider the complexity of using the cubic function. There are no specific constraints on the coefficients a, b, c, and d.
jjj888
23
Here's the equation:
slove for t
x=at^3+bt^2+ct+d
Parametic Equations, removing the t value and such, to "simplify" the equation.
This is as far as I got:
(x-d)/t = t^2(a+(b/t)+(c/t^2))
I'm stumped. Is this even possible?
Thanks
There is a general method of expressing the roots of a cubic equation in terms of its coefficients, but it is far more complicated than the quadratic formula. You can find it here: http://en.wikipedia.org/wiki/Cubic_function
Are there any constraints on a, b, c, and d?
Thanks, yea that looks pretty crazy, but interesting. I had a feeling it was headed that way, I wasn't aware of the cubic function. a,b,c,and d are basically a single real number value, if that's what you mean.
Thanks!
What is parametric conversion?
Parametric conversion is a mathematical process that involves transforming a set of data from one form to another, using a set of mathematical equations or functions.
What are some common applications of parametric conversion?
Parametric conversion is commonly used in fields such as engineering, physics, and economics to convert data from one form to another, such as from Cartesian coordinates to polar coordinates.
How is parametric conversion different from non-parametric conversion?
The main difference between parametric and non-parametric conversion is that parametric conversion uses a predetermined set of equations or functions to transform the data, while non-parametric conversion does not rely on any specific equations or assumptions.
What are some common challenges faced when performing parametric conversion?
One of the main challenges of parametric conversion is determining the appropriate equations or functions to use for the conversion, as well as ensuring that the data is accurately represented in the new form.
How can parametric conversion be beneficial in scientific research?
Parametric conversion can be beneficial in scientific research as it allows for the analysis and interpretation of data in different forms, which can provide new insights and understanding of complex systems or phenomena.
