Subsea Power Generation: A New Approach to Sustainable Energy
  • Thread starter Thread starter Physics2010e
The discussion revolves around a proposed subsea power generation system utilizing air-filled tanks to create lift and generate energy, inspired by the mechanics of hydroelectric power. The idea involves using natural gas to produce energy before combustion and suggests potential applications in various underwater environments. However, participants express skepticism about the feasibility, citing concerns that the energy required to pump air or gas underwater may exceed the energy produced. There is also a call for more detailed explanations regarding the system's mechanics and energy output. Overall, the concept raises questions about its adherence to physical laws and practical implementation.
Physics2010e
Hello
I have figured out a way that we maybe can generate power with.
I have talked with some people but they doesn't understand my idea.
I am not to good in the math / physics. But i like to invent things.
If you look at the picture: Subsea airwheel.jpg, then what i thinking of is that we can put air
into the open tanks from 6 o clock till 9 - 1+ o clock. Then at 12 o clock the air runs out
itself. The tanks are automaticly filled with water and sinks again. When I say clock I only
try to explain the position of the wheel.
I have tried to fill a little air in a bottle with water, and I see that it generates a huge
amount of lift.
Why not use the air's lifting power? Can even run at night time. And in quiet water.
What I am thinking of running this wheel with is:
-nature gas.
Because we can produce energy of this gas before even burning it.
If you want you can produce hermetic systems which can use the gas many times. (i hope so). If they beeing put on top of each other.
-maybe we can use it on Iceland?
-The black shimneys in the oceans?
-What about cooking water from the Earth's magma and use the steam in the wheel.
I hope some of you see my idea.
I thinking of this because some day the oil will run out and we need alternatives.
I got this idea from my aquarium. Why not use rising air.
It's kinda reversal system of hydroelectric powerplants.
Maybe this is against the physics laws. This is why I ask you in this forum.
Getting the air down to the depths required plus pumping it into the tanks at the bottom (evacuating the water) would require more energy than you get out of the system.
This is an over unity device as far as I can see, so it won't work.
You may want to provide more details before this thread gets locked.
Physics2010e said:
Hello
amount of lift.
-nature gas.
As jarednjames says, it takes more energy to pump the air or natural gas down into the water than you get back out from the motion of the wheel.
However, if you were tapping natural gas from under the seafloor, that's a different situation. You could extract some energy from the compressed natural gas as you let it rise to the surface (like maybe with turbines or something), but it probably wouldn't be all that much energy.
That's actually the sort of thing I was hoping the OP would clarify, but I also wanted a bit more detail such as how long enough pressure would remain to keep the system producing energy (how long would gas pressure remain able to pressurise the chambers).
Thank you everyone for your quick response.
It's nice to get things clarified.
Merry cristmas to all of you in the Physics Forums.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
