Why Is Fire Hotter with Sulfur Fuel?
In summary, the temperature of a fire depends on the energy released from the chemical reaction. The heat of combustion is released for the reactions of S + O2 -> SO2, and C + O2 -> CO2. The heat of combustion for the reaction of C + O2 -> CO2 must compete with the heat of combustion for the reaction of C+O -> CO. The heat of combustion for the reaction of S + O2 -> SO2 is release faster than the heat of combustion for the reaction of C + O2 -> CO2 because the burning process proceeds faster in your equipment.
ffrancis
Why is fire hotter when fueled by sulfur as compared to say, paper, wood, or charcoal?
Chemistry news on Phys.org
Where did one find a statement that indicates burning sulfur produces a hotter fire than paper, wood, or charcoal?
The temperature depends on the energy released from the particular chemical reaction.
Find the enthalpy (per mole) or heat of combustion (in pure oxygen) released for the reactions
S + O2 -> SO2, and
C + O2 -> CO2, which must compete with C+O -> CO.
Check one's chemistry book.
I don't think you would want to use sulfur as a fuel. The product of combusting sulfur, SO2, could form sulfuric acid which would produce acid rain. The EPA has been trying to cut SO2 emissions for decades.
Your dam right gravenewworld, it could end up with SO2 or SO3 +H20 = H2SO3 or H2SO4 like you’ve said, Sulfurous acid or Sulfuric acid
EDIT: And in black powder, sulfur is just a stabilizer to make the KNO3 and C burns better, to me sulfur just reminds the black powder to burn with better results
I read it somewhere long time ago but I couldn't remember which book or publication.
Is volcanic lava sulfuric?
How about, where and how is sulfur produced in nature?, all I know it’s always available near volcanoes
sulfur is everywhere in nature. a lot of SO2 is released when a volcano erupts. you also see a lot of sulfur in the human body. one of the characteristics of the tertiary structure of proteins is a disulfide bond. sulfur is also used a lot in medicines. mesylate salts of drugs are made to create prodrugs, although a lot of times this creates allergic reactions in the body.
Yip I know, but how is sulfur made/created by nature? Magic question
How is carbon made, how is hydrogen made, etc? Elements exist because they have always been there. The only way to "make" sulfur would be to smush the right amount of protons into the nucleus.
Carbon is probably from some dead trees and some volcanic heat underground without the presence of mr. oxygen, but that “smush the right amount of protons into the nucleus” is the **** man! LOL
Sulfur is made from hydrogen sulfide in volcanoes. Hydrogen sulfide is made from the thermal decomposition of sulfates (or biological reduction) in contact with low valent metals and water deep within the earth. Hydrogen sulfide gas rises until it reaches the surface and combines with oxygen to produce elemental sulfur. It also happens in some sewer systems. Layers of yellow sulfur are sometimes visible in manholes where air has come into contact with hydrogen sulfide (sewer gas).
Standard heat of formation data:
CO2 -393.51 KJ
SO2 -296.9 KJ
SO3 -395.2 KJ
Thats the heat data. "Hotter" refers to temperature which is a function of how fast something burns and how much heat is produced per unit weight. Paper, wood or charcoal will burn hotter if you provide oxygen fast enough. If your observation is that a sulfur flame is hotter by some thermal measurement, it is because the burning process proceeds faster in your equipment for some reason. Charcoal burns somewhat cooler because is is covered with an ash coating that is not present in burning sulfur. Try adding oxygen to it and see what happens!
See here:
http://www.columbiatribune.com/2005/Jul/20050703Comm006.asp
This is some hardcore quality stuff man, thanks :rolleyes:
1. Why is sulfur fuel used in fire?
Sulfur fuel is often used in fire because it has a low ignition temperature and can easily combust, making it a reliable and efficient source of heat and energy.
2. How does sulfur fuel make fire hotter?
Sulfur fuel has a high energy content, which means it releases more heat when burned compared to other fuels. This results in a hotter and more intense fire.
3. Is sulfur fuel more dangerous to use in fire?
Sulfur fuel can be more dangerous to use in fire compared to other fuels because it releases toxic gases and chemicals when burned. It is important to take proper precautions and use it in a well-ventilated area.
4. Can sulfur fuel be used in all types of fire?
Sulfur fuel can be used in most types of fire, but it may not be as effective in certain situations. For example, it may not be suitable for use in a fire that requires a high level of precision or control.
5. How does sulfur fuel affect the environment?
Sulfur fuel can have negative impacts on the environment. When it is burned, it releases sulfur dioxide, a harmful gas that contributes to air pollution and acid rain. It is important to use sulfur fuel responsibly and find alternative, cleaner sources of energy.
12K
  • Nuclear Engineering
